09-28-2007 05:32 AM - edited 03-05-2019 06:45 PM
I have a 3400ME 12CS 4SFP Metro switch connected to a 7606 Cisco router via a dot1q trunk port. On the 3400's port facing the 7606 I receive valid but too small of frames (or undersized frames). The 7606 shows RCV-errs because of the Input queue show that it has dropped numerous packets. I have tried new x-over cables, different ports on both devices, and changing from forced 100, full duplex to auto negotiate. I am getting stumped, I have setups like this in other locations and have compared configs with clean ones and nothing seems to be out of sorts. Any suggestions?
10-04-2007 12:20 PM
This might indicate that this port is trunking dot1q and is receiving 64byte frames (including dot1q header).
Only impact should be that the counter increments. I think you have fixed the limit for queue. If it wills exceeded this no. it will drop the packet.
10-18-2007 03:29 AM
Try adding
system mtu jumbo 1504
to all switches
see
Anthony
10-18-2007 04:51 AM
Thanks to both of your responses I appreciate it. I replaced the 3400ME with a catalyst 3560 and the problem continued. The MTU sizes have been set to 1518 actually, and the problem continues.
10-18-2007 06:00 AM
How is your trunk setup?
mode trunk or mode desirable? If mode trunk then switchport nonegotiate.
I had a similiar problem running an lacp etherchannel trunk. I switched it to mode on and it fixed the problem, but I'm guessing your running a normal non ec single link trunk?
10-18-2007 06:49 AM
Here is the 7606 (WS-X6548-RJ-45) phy port config. It is set to trunk mode on as well is the 3400 trunk interface.
interface FastEthernet1/20
description Trunk to 3400ME GE0/10
no ip address
switchport
switchport trunk allowed vlan 2109,2116
switchport mode trunk
Again thanks for the input on this issue.
