Understanding Etherchannel
There is an Etherchannel in in network I am working on between two Cat6509. But for some reason there is no traffic. I am not an Etherchannel specialist. I have read most of Cisco's white papers related to this subject but I still don't really understand the use of it on Distrib layer as the 6500 are at the the distribution layer. Could anybody explain me the way it works ? I also would like to generate some traffic on it but don't really how to proceed.
Thanks in advance.
Rgds.
Re: Understanding Etherchannel
I forgot to mention my question is about L2 EC.
Hall of Fame Super Bronze
Is this CATOS or IOS ?
thibault,
Are you running hybrid OS or native OS on the 6500.
Ether-channel is primarily used for port aggregation by bundling switchports for bandwidth aggregation.A typical ether-channel configuration is to run an ether-chanel from the access-switches to the distribution switches for bandiwdth aggregation.In your network scenario, your access switches will be uplinked to 6500's with ether-chanel to provide more throughput.
Please see the links below for more understanding of the ether-channel:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/channel.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_7_6/confg_gd/channel.htm
HTH,
-amit singh
I am using IOS 12.2
In fact I have understood the aggregation process. What I don't understand is the L2 links between the 2 cat6500 as it seems there are no uplinks between access switches(3750) and the 6500. I just wonder what kind of traffic(if any) that is not VLAN related could pass through this etherchannel as it is L2.
Rgds.
As you have a L2 etherchannel between the 2 6500 which are primarly used for bandwidth aggregation,the normal vlan traffic will be passed between the switches. If there is not Vlan traffic at this moment, you normal Layer 2 control traffic will still travel across the link like CDP,VTP,STP,Pagp/LACP,DTP.
HTH,
-amit singh
Let's see if your etherchannel is properly configured.
Please post the output from typing
show ether sum
in exec mode.
Well thank you for you answers.
I have removed the etherchannel as there was no traffic on it. I'd rather use features I fully understand ^^. Links are now L3 and added to ospf area.
Rgds.
197
