Understanding Group Policy's in CLient VPN's
Can someone explain me what exactly the tunnel-group and group-policy does in VPN client configuration. Can someone explain with a simple language not refering to any document as im non-techie guy
below is the configuration i would be very thankfull if you can explain me what exactly each line of config does in helping to connect to client VPN from remote. I know this is part of the configuration but im concerned with these lines..
tunnel-group CiscoVPN_TG type remote-access
tunnel-group CiscoVPN_TG general-attributes
 address-pool Pool_Users
 authentication-server-group TACACS_Servers
default-group-policy CiscoVPN_GP
tunnel-group CiscoVPN_TG ipsec-attributes
ikev1 pre-shared-key (15 Alphanumeric with Special Characters)
group-policy CiscoVPN_GP internal
group-policy CiscoVPN_GP attribute
 dns-server value 8.8.4.4
 vpn-tunnel-protocol ikev1 ikev2
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value Restrict_ACL
1 REPLY
Hi Srikanth,Explaining VPN in
Hi Srikanth,
Explaining VPN in complete is bit difficult. But let me try to explain as simple as possible.
<< The above command you are selecting the type of VPN configuration , whether RA or L2L etc. Here it is client to site VPN ( Remote Access) is chossen >>
<< The above command specifies the generic configuration parameters to be define for the VPN >>
<< VPN Client user will get thye IP address assigned from the specific pool name ( Pool_Users). Some where DHCP would have been created in this name >>
<< Users from VPN client will get autheticated through the TACACS/Radius server pointed there. There should be some AAA configuration related to group ( TACACS_Servers) >>
<< It defines the default group policy >>
<< earlier it was generic atrributes for the RA VPN. Now we are getting in to IP Sec Specific attributes >>
<< for VPN Client to VPN Server authentication is done with pre-shared Key. This key should match on the VPN client configuration ( User's PC VPN Application) and VPN Server ( Firewall configuration here) >>
<< Group policy can be either internal or external. It defines the user specific attribute.
group-policy CiscoVPN_GP attribute << User Specific Attributes >>
<< DNS Value  for the tunnel >>
<< Internet Key Exchange Protocol Version Specifications IKEV1/2>>
<< Here they want to route only the specific traffic over VPN tunnel. Rest all will take the default path of the end user connection. >>
<< Only allowed subnets / hosts in the ACL line will be allowed through VPN tunnel. Rest all will go through the local gateway >>
I hope i have explained for a better understanding.
Hope this helps.
24
