Understanding SHOW INTERFACE
Hi!
One of our switches (WS-C3548-XL) in the server room is generating several errors on several interfaces. Here is one example:
FastEthernet0/2 is up, line protocol is up
Hardware is Fast Ethernet, address is 0002.166b.b342 (bia 0002.166b.b342)
Description: ***ACCESS PORT***
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Auto-duplex (Full), Auto Speed (100), 100BaseTX/FX
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 15:39:55
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 7000 bits/sec, 5 packets/sec
5 minute output rate 83000 bits/sec, 28 packets/sec
2353394 packets input, 420873627 bytes
Received 378 broadcasts, 0 runts, 0 giants, 0 throttles
1070 input errors, 1070 CRC, 0 frame, 4352 overrun, 4352 ignored
0 watchdog, 0 multicast
3550965 packets output, 1053192180 bytes, 0 underruns
0 lost carrier, 0 no carrier
Where do I get information what could be causing the overruns, input errors, CRCs, etc.?
Regards, LLS71
Purple
Re: Understanding SHOW INTERFACE
Check the server nics to see how they are set . The switch is set for auto speed and duplex so the server nics must also be set for auto speed and duplex , they "cannot" be hardcoded to a specific speed and duplex unless you hardcode the switch also.
Do you know where I can get detailed information about the errors (overrun, etc.)?
Regards, L. Schieder
This link should help in uderstanding and troubleshooting the same.
http://cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af0.shtml
HTH,Please rate if it does.
-amit singh
178
