UNI to NNI port conversion
I am having one Cisco ME 3400G-12CS switch with 4 NNI port & 12 UNI port.I want to convert all UNI port to NNI to as meet my client requirements.Please guide me which Metro IP Access Image IOS  version is required to convert those UNI port to NNI.
Mukesh
1 REPLY
Re: UNI to NNI port conversion
Hello Mukesh,
This is pretty much supported in most of the Metro switch images. The conversion is supported in 12.2(25)SEG and 12.2(50)SE as well.
Please note When you change a port from UNI to NNI or the reverse, any features exclusive to the port type are removed from the configuration to prevent conflicting configuration options on a specific interface type.
Switch# configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)# interface fastethernet0/1
Switch(config-if)# port-type nni
Switch(config-if)# no shutdown
5d20h: %SYS-5-CONFIG_I: Configured from console by console
Switch(config-if)# end
Switch# copy running-config startup-config
Reference:
http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_25_seg_seg1/configuration/guide/swint.html#wp1554661
Ricky Micky
*Pls rate useful posts
1067
