11-27-2006 06:40 AM - edited 03-05-2019 01:02 PM
I set up a SPAN/monitor source and destination port. I have a server attached to the source port, and a sniffer attached to the destination port.
When I run my sniffer, I expect to see traffic to or from the server that is on the source port, in addition to broadcast traffic. However, I am also seeing traffic to and from other IP addresses. How can this be if I only have a single server with one IP address on the source port? This is really throwing off my intrusion sensor because it's seeing parts of conversations from servers that are not on this port. I confirmed with a sniffer. Please help!
Source port:
interface GigabitEthernet8/0/36
description blah blah blah
switchport access vlan 17
spanning-tree portfast
Destination port:
interface GigabitEthernet8/0/24
SPAN config:
monitor session 2 source interface Ga8/0/36
monitor session 2 destination interface Ga8/0/24
P.S. I tried adding the dest port to the vlan too, but no dice :-(
11-27-2006 06:43 AM
Jim
I do not believe that there is enough information here for us to be able to find the source of your problem. Can you give us specifics of what platform you have configured this on? what version of code is running? can you post the output of show port 8/0/36, show port 8/0/24 and of show vlan 17? Also I note that you are configuring session 2. Is there a session 1 and if so how is it configured? If we had that we might be in better position to give you good advice.
Rick
11-27-2006 06:52 AM
Sorry:
3750 switches configured in a stack. Source and dest ports are on the same switch (10/100/1000 swtich). There is one 10/100/1000 switch, the rest are 10/100 switches. let me know what else you need.
switch#sh ver
IOS (tm) C3750 Software (C3750-I9-M), Version 12.2(20)SE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Sun 09-Jan-05 00:09 by antonino
Image text-base: 0x00003000, data-base: 0x0099748C
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWARE (fc)
switch uptime is 1 year, 5 weeks, 3 days, 22 hours, 2 minutes
System image file is "flash:c3750-i9-mz.122-20.SE4.bin"
cisco WS-C3750G-48TS (PowerPC405) processor (revision C0) with 118784K/12280K bytes of memory.
Processor board ID FOC0935U1XS
Last reset from power-on
8 Virtual Ethernet/IEEE 802.3 interface(s)
336 FastEthernet/IEEE 802.3 interface(s)
80 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:15:62:xx:xx:xx
Motherboard assembly number : 73-9366-08
Power supply part number : 341-0107-01
Motherboard serial number : xxxx
Power supply serial number : xxxx
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C3750G-48TS-S
System serial number : xxxx
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : xxxx
Top Assembly Part Number : 800-25409-02
Top Assembly Revision Number : A0
Version ID : 02
CLEI Code Number : CNMWU00ARB
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
1 52 WS-C3750-48TS 12.2(20)SE4 C3750-I9-M
2 52 WS-C3750-48TS 12.2(20)SE4 C3750-I9-M
3 52 WS-C3750-48TS 12.2(20)SE4 C3750-I9-M
4 52 WS-C3750-48TS 12.2(20)SE4 C3750-I9-M
5 52 WS-C3750-48TS 12.2(20)SE4 C3750-I9-M
6 52 WS-C3750-48TS 12.2(20)SE4 C3750-I9-M
7 52 WS-C3750-48TS 12.2(20)SE4 C3750-I9-M
* 8 52 WS-C3750G-48TS 12.2(20)SE4 C3750-I9-M
Vlan17 is up, line protocol is up
Hardware is EtherSVI, address is 0015.624d.7e41 (bia 0015.624d.7e41)
Internet address is 172.17.1.5/16
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4000 bits/sec, 8 packets/sec
5 minute output rate 5000 bits/sec, 5 packets/sec
27766719 packets input, 4009704270 bytes, 0 no buffer
Received 0 broadcasts (4055984 IP multicast)
2334939 packets output, 200024168 bytes, 0 underruns
0 output errors, 0 interface resets
Couldnt fit everything, please see post below:
11-27-2006 06:57 AM
GigabitEthernet8/0/24 is up, line protocol is down (monitoring)
Hardware is Gigabit Ethernet, address is 0015.62ss.ssss (bia 0015.62ss.ssss)
Description: ssss
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:01:52, output hang never
5 minute output rate 178000 bits/sec, 44 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicast)
0 watchdog, 0 multicast, 0 pause input
31919794 packets output, 2342117797 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
GigabitEthernet8/0/36 is up, line protocol is up (connected)
Description: ssss
Last input never, output 00:00:01, output hang never
5 minute input rate 561000 bits/sec, 67 packets/sec
5 minute output rate 99000 bits/sec, 49 packets/sec
1013091294 packets input, 2833088873 bytes, 0 no buffer
Received 137839 broadcasts (0 multicast)
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
589915090 packets output, 2305917226 bytes, 0 underruns
11-27-2006 07:03 AM
I believe that if the destination mac is not in the cam table of the switch that the unicast traffic is broadcast until the switch determines the mac and updates its cam table. For more info search the Cisco site for "unicast flooding".
If you review your packets traces you probably only see the start of unicast conversations.
If this causes you problems or concerns try looking into making the server port a private vlan port. I don't have much experience with pvlan ports so take care that it meets your requirements.
Hope that helps...
11-27-2006 08:31 AM
Ohh, that seems to make sense. Looking into it now. In the meantime, thanks!
11-27-2006 10:54 AM
Just a slight correction:
The frames are not "broadcast" they are flooded.
Broadcast implies a MAC destination of all ones (ff.ff.ff.ff.ff.ff); a flood puts the original frame (original source & destination addresses) out all but the ingress port.
Otherwise, I believe Mike is correct.
FWIW
Scott
11-27-2006 02:08 PM
Yeah, was a typo. The link he posted is definitely steering me in the right direction. It is indeed flodding as I am no longer SPANing the port, but instead added the port as a standard port on our VLAN and I see flodded traffic (the original source and destination MACs as well as FF:FF:FF:FF:FF:FF).
We have 2 switch stacks which are trunked together via fiber. Not sure why, but the trunks are on their own VLAN (vlan 18 where our workstations and servers are on vlan 17). The problem seems to be traffic on vlan17 from the far switch coming into our main switch on vlan17. This traffic seems to be flooded because the hosts on the far switche's MAC addresses do not show up in the main switch's CAM table.
11-27-2006 03:52 PM
(Quote)
(End Quote)
This would be normal behavior.
If the frame is destined for a host on the switch to which it is connected, and it has "talked" within the timeout value of the forwarding/CAM table, the frame is forwarded to the destination.
If the frame does contains a MAC that is not in the forwarding/CAM table, then the switch would flood the frame (to all ports in the VLAN except the ingress port).
For hosts connected to the far switch, unless they have recently "talked" to a device on our Main switch, then the far switch would have to flood to find the destination host.
I suspect the interconnect was put on its own VLAN to limit the broadcast trafic from one switch to the other (the intermediate L3 process would block broadcasts by default).
It doesn't sound like you are using actual trunks (i.e., 802.1q)to connect the two switches ... just high-speed links from access-port to access-port ... in which case VLANs don't really matter (and the reason you far switch is flooding so much).
If you used 802.1q trunking, the VLANs on the far switch would be part of the same broadcast domain as the same VLAN on the Main switch, and the forwarding/CAM tables would be updated when any host in that VLAN on either switch "talked."
FWIW
Good Luck
Scott
11-28-2006 06:41 AM
I believe they are using 802.1q. Here's the config from the main/near switch:
VTP Version : 2
Configuration Revision : 12
Maximum VLANs supported locally : 1005
Number of existing VLANs : 13
VTP Operating Mode : Server
VTP Domain Name : abcd
VTP Pruning Mode : Disabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0x7A 0x56 0x9A 0x41 0x07 0xD6 0x1E 0x6F
Configuration last modified by 0.0.0.0 at 7-5-94 10:05:11
Local updater ID is 172.17.1.5 on interface Vl17 (lowest numbered VLAN interface found)
interface Port-channel1
switchport mode trunk
interface Port-channel2
interface GigabitEthernet2/0/1
description Trunk-Link
channel-group 2 mode on
interface GigabitEthernet2/0/2
interface GigabitEthernet7/0/1
channel-group 1 mode on
interface GigabitEthernet7/0/2
interface Vlan17
ip address 172.17.1.5 255.255.0.0
no ip unreachables
Config from the far switch:
VTP Version : 2
VTP Operating Mode : Client
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet4/0/1
interface GigabitEthernet4/0/2
11-30-2006 11:43 AM
Found the problem!
We have very infrequest commincations going on between several machines. By default, the switch's CAM table removes MAC addresses every 300 seconds (every 5 minutes). The flooding recurred every 10 or so minutes so by that time, the MAC addresses were no longer in the CAM table. I increased the timeout to 900 seconds and it solved my problem!
Thanks everyone for your assistance!!!
11-27-2006 05:26 PM
More than likely unicast flooding.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801d0808.shtml
