Webcast-Catalyst9k
Unknown ACL's on 4500 series switch
I was working at a client site of mine this morning. I was configuring some modifications to a couple of the known ACL's configured on the box.
I did a "sh access-list" command and received some very strange output. here is what I received:
bhicore#sho access-list
Extended IP access list PCI-vlan1-egress
10 permit ip 198.100.100.0 0.0.0.255 any (1168573 matches)
Extended IP access list PCI-vlan2
Extended IP access list system-cpp-all-routers-on-subnet
10 permit ip any host 224.0.0.2
Extended IP access list system-cpp-all-systems-on-subnet
10 permit ip any host 224.0.0.1
Extended IP access list system-cpp-dhcp-cs
10 permit udp any eq bootpc any eq bootps
Extended IP access list system-cpp-dhcp-sc
10 permit udp any eq bootps any eq bootpc
Extended IP access list system-cpp-dhcp-ss
10 permit udp any eq bootps any eq bootps
Extended IP access list system-cpp-igmp
10 permit igmp any 224.0.0.0 31.255.255.255
Extended IP access list system-cpp-ip-mcast-linklocal
10 permit ip any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-ospf
10 permit ospf any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-pim
10 permit pim any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-ripv2
10 permit ip any host 224.0.0.9
Extended MAC access list system-cpp-bpdu-range
permit any 0180.c200.0000 0000.0000.000c
Extended MAC access list system-cpp-cdp
permit any host 0100.0ccc.cccc
Extended MAC access list system-cpp-cgmp
permit any host 0100.0cdd.dddd
Extended MAC access list system-cpp-dot1x
permit any host 0180.c200.0003
Extended MAC access list system-cpp-lldp
permit any host 0180.c200.000e
Extended MAC access list system-cpp-mcast-cfm
permit any 0100.0ccc.ccc0 0000.0000.0007
Extended MAC access list system-cpp-sstp
permit any host 0100.0ccc.cccd
Extended MAC access list system-cpp-ucast-cfm
permit any host 001a.a11c.84bd
I do not know what the bottom 18 ACL's are. I DO know that I didnt configure them. Has anyone out here in the braintrust seem these before, and if so, what are they? Is there some configuration option that enables these ACL's??
Thx
Kevin
1 ACCEPTED SOLUTION
Re: Unknown ACL's on 4500 series switch
Those are the CoPP: Control Plane Policy ACL.
They are needed for the functioning of your switch. They are not seem in a show run, but a show access-lists displays them.
The access-lists were introduced as part of the control-plane policers
from 12.2(31)SG onwards.
The document on configuring CoPP details the access-lists for a cat4k:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/cntl_pln.html
I dont know what platform you have but if you search on cisco.com you will find a document for your switch.
1 REPLY
1687
