12-04-2006 07:00 PM - edited 03-05-2019 01:10 PM
Last Friday all my network went blank and I had to switch off/on both the Catalyst 4506 to get access. Then I receive e-mail from NMS stating that all my propvirtual was unresponsive at that time. Can anybody tell me what happen?
12-04-2006 09:57 PM
did you observe any logs on the switches during that time. If yes, can you share it with us?
12-04-2006 10:52 PM
I'm not sure which log you referring to but I have a Device Fault Manager logs on both catalyst.
Hope this is the right one.
12-04-2006 11:00 PM
.253 is the PROPVIRTUAL IP
12-04-2006 11:27 PM
I was referring to the "show log" command on the switches to check if any information is recorded in the log buffer of switches which indicates of any problem.
you can also check on the switches as which interface is assigned with .253 IP.
12-05-2006 12:24 AM
12-05-2006 12:45 AM
Can you detect it ?
Or is it not the right one?
12-05-2006 01:33 AM
i can see lot of traceback errors in the log which can be due to an IOS bug. Not sure if it occured at the time you have faced the problem or not as date and time stampings were not there for log event.
can u put output of "show stacks" and "show version" from your devices.
12-05-2006 04:00 PM
Sorry for the late entry. I have to take care of some business elsewhere. This is the stack and version information.
Minimum process stacks:
Free/Size Name
82456/86000 Routekernel Process
31760/32000 CDP BLOB
31704/32000 SPAN Subsystem
31616/32000 Netboot process
37432/38000 Router Init
5560/12000 Init
34752/35000 cdp init process
31536/32000 RADIUS INITCONFIG
28560/29000 Rom Random Update Process
33168/36000 TCP Command
54712/60000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 0 9000/9000 Level 1
2 0 9000/9000 Level 2
3 28407272 8240/9000 Level 3
4 140 8920/9000 Level 4
5 100555245 8680/9000 Level 5
6 0 9000/9000 Level 6
7 0 9000/9000 Level 7
4506_Rack_A#sh version
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA2, RELEASE
SOFTWARE (fc2)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 05-Jul-05 13:21 by ccai
Image text-base: 0x10000000, data-base: 0x114DD0D4
ROM: 12.2(20r)EW1
Dagobah Revision 95, Swamp Revision 29
4506_Rack_A uptime is 4 days, 15 hours, 43 minutes
System image file is "bootflash:"
cisco WS-C4506 (MPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID FOX092909ZL
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from PowerUp
22 Virtual Ethernet interfaces
44 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
Configuration register is 0x2101
12-05-2006 09:36 PM
I guess output of show version is incomplete.
Please paste the complete output of the show version command for analysis.
12-06-2006 03:47 AM
Sorry to say that is all there is. No more. After going through it seems that one of the switch is issues with redundancy as the switches are configure to load-balance and only certain Vlan was having problems. On the other switch it looks ok.
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes,
0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 23 messages logged, xml disabled,
filtering disabled
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 27 message lines logged
Logging to 10.10.1.17, 27 message lines logged, xml disabled,
filtering disabled
Log Buffer (4096 bytes):
00:00:35: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:36: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-X4515 Hw: 4.2) is online
00:00:36: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 2 (WS-X4306-GB Hw: 4.0) is online
00:00:36: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 3 (WS-X4306-GB Hw: 4.0) is online
00:00:36: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 4 (WS-X4306-GB Hw: 4.0) is online
00:00:36: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 5 (WS-X4424-GB-RJ45 Hw: 1.7) is online
000007: *Dec 1 00:46:22: %SYS-5-CONFIG_I: Configured from memory by console
000008: *Dec 1 00:46:23: %SYS-5-RESTART: System restarted --
.2(25)EWA2, RELEASE SOFTWARE (fc2)
000009: *Dec 1 00:46:23: %SNMP-5-COLDSTART: SNMP agent on host 4506_Rack_B is u
ndergoing a cold start
000010: *Dec 1 00:46:26: %EC-5-BUNDLE: Interface GigabitEthernet1/1 joined port
-channel Port-channel1
000011: *Dec 1 00:46:26: %EC-5-BUNDLE: Interface GigabitEthernet1/2 joined port
000012: *Dec 1 00:47:23: %HSRP-6-STATECHANGE: Vlan2 Grp 2 state Standby -> Acti
ve
000013: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan4 Grp 4 state Standby -> Acti
ve
000014: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan6 Grp 6 state Standby -> Acti
ve
000015: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan8 Grp 8 state Standby -> Acti
ve
000016: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan10 Grp 10 state Standby -> Ac
tive
000017: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan12 Grp 12 state Standby -> Ac
tive
000018: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan14 Grp 14 state Standby -> Ac
tive
000019: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan16 Grp 16 state Standby -> Ac
tive
000020: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan18 Grp 18 state Standby -> Ac
tive
000021: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan20 Grp 20 state Standby -> Ac
tive
000022: *Dec 1 00:47:25: %HSRP-6-STATECHANGE: Vlan22 Grp 22 state Standby -> Ac
tive
000023: *Dec 4 16:44:37: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet receiv
ed with invalid source MAC address (00:00:00:00:00:00) on port Gi2/6 in vlan 8
