Community Member
Unsupported module WS-X4648-RJ45-E on WS-C4507R-E
Hi all, I installed a WS-X4648-RJ45-E on C4507 chassis and module stay Unsupported. Someone can tell whats wrong? My IOS is not with the last update but according the documentation this version is supported by module... tnks respect
SBT_CORE>show module
Chassis Type : WS-C4507R-E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
 1    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE1328DSFX
 2    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45   JAE140208A8
 3     6  Sup II+10GE 10GE (X2), 1000BaseX (SFP) WS-X4013+10GE      JAE1330F18J
 5    48  10/100BaseTX (RJ45)                    WS-X4148-RJ        JAE14190F74
 6     0  Unsupported module                     WS-X4648-RJ45-E    JAE1734090T
 M MAC addresses                    Hw  Fw           Sw               Status
 1 0026.0bf5.64d0 to 0026.0bf5.64ff 2.5                               Ok
 2 001e.f7be.e660 to 001e.f7be.e68f 2.5                               Ok
 3 0025.45ce.f440 to 0025.45ce.f445 1.8 12.2(31r)SGA 12.2(54)SG1      Ok
 5 5475.d099.6860 to 5475.d099.688f 3.4                               Ok
 6 c08c.6041.f700 to c08c.6041.f72f 2.1                               Unsupport
Mod  Redundancy role     Operating mode      Redundancy status
 3   Active Supervisor   SSO                 Active
SBT_CORE>sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 11:43 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11ED6EBC
ROM: 12.2(31r)SGA4
Pod Revision 16, Force Revision 31, Tie Revision 32
SBT_CORE uptime is 10 weeks, 6 days, 21 hours, 36 minutes
Uptime for this control processor is 10 weeks, 6 days, 21 hours, 36 minutes
System returned to ROM by reload
System image file is "bootflash:/cat4500-ipbase-mz.122-54.sg1.bin"
cisco WS-C4507R-E (MPC8540) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX1307GZNN
MPC8540 CPU at 667Mhz, Supervisor II-PLUS-10GE
Last reset from Reload
20 Virtual Ethernet interfaces
48 FastEthernet interfaces
100 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
1 ACCEPTED SOLUTION
WS-X4648-RJ45-E • Supported
WS-X4648-RJ45-E • Supported on by the Supervisor Engine 6-E,
Supervisor Engine 6L-E, and the Supervisor Engine 7-E
 • Supported only in the Catalyst 4503-E,
Catalyst 4506-E, Catalyst 4507R+E, and
Catalyst 4510R+E switch chassis.
 • Can be installed in any non-supervisor engine
slot.
 • Catalyst 4503—48/96
 • Catalyst 4506-E,
Catalyst 4507R+E—48/240
 • Catalyst 4510R+E—48/384
 • You need a Supervisor Engine 7-E to
support more than 240 ports on the
Catalyst 4510R-E and Catalyst 4510R+E
switch chassis
Inayath
Hall of Fame Super Blue
There's nothing you can do.
There's nothing you can do.  The line card "WS-X4648-RJ45-E" is supported with Sup6E and you've got a Sup2+.
slot.
 • Catalyst 4506-E,
switch chassis
Inayath
519
