Community Member
Upgrade 2960S IOS
Dear Expert,
Is it possible to upgrade the IOS of WS-C2960S-48TS-S (LAN Lite Entry Layer 2)  to LAN base Layer 2?
The IOS is retrieved from "WS-C2960S-48TS-L (LAN Base Layer 2)"
I understand that some services and features may not be activated properly, such know the possibility. Thank you
rdgs
1 ACCEPTED SOLUTION
Community Member
Re: Upgrade 2960S IOS
Dear Anitachoi,
It is not possible to upgread IOS from LAN Lite to LAN base as both are different Hardwere platform.
Please reffer the link on Cisco site:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/prod_qas0900aecd80322c37.html
Hope this will help you.
Please do not forgot to rate the post if it will helpful to you.
Community Member
Dear Anitachoi,
Hall of Fame Super Blue
No.  It's not possible due to hardware limitation.
1302
