07-16-2008 01:18 PM - edited 03-06-2019 12:14 AM
Hello all
I'll be upgrading one 6509 from SUP1A with a SUP720-3B one. I need to know if there is a working tool that allows me to convert the configuration before installing the new card. I've donwloaded EDI tool, but i can't make it work (the installer seems to be wrong). I've downloaded it from https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=ccu-forum
07-16-2008 03:12 PM
I wish there was such a tool as I've been searching as well for one! The EDI tool only converts the IOS image from CatOS for you, but its a java based program. You might as well manually follow the conversion instructions from the online document since it will be faster than trying to figure out how the EDI works and getting the necessary text files for it.
I've done this many times and have always done a "show config" in CatOS, "show config" in the MSFC... then combined it to paste into a native IOS SUP720-3B.
07-16-2008 04:00 PM
Thanks my friend for the advice, so, i'll have to do what i didn't want to do.
Best regards
