Upgrade 7606
Can someone indicate documentation to upgrade an 7606 router with an RSP720-3C-GE?
Best regards.
Re: Upgrade 7606
Hey Norberto,
Are you looking for documentation on how to install/upgrade an RSP or upgrade the IOS on the box?
Brandon
Re: Upgrade 7606
Hi Brandon,
Thank you for your reply.
I want to upgrade the IOS from version 12.2(33)SRD2 to 12.2.(33)SR1. I can't find documentation specific for RPS720. I have the idea that the upgrade it's pretty much as an upgrade of a SUP720 in a 6500, but I wanted to check it.
Thank you.
Best regards
Re: Upgrade 7606
Hey Norberto,
You are correct.  The upgrade procedure that is used for 6500 dual SUP configurations, known as FSU (Fast Software Upgrade), can also be used for the 7600 RSP upgrades.  This procedure is detailed here -
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080a98f3c.shtml#native
Depending on your RSP configuration, you may also have the option to use the eFSU or ISSU methods detailed here -
http://www.cisco.com/en/US/partner/docs/routers/7600/ios/12.2SR/configuration/guide/efsuovrw.html
Both eFSU and ISSU were first supported in 12.2(33)SRB and can be done with the following cards (a full list can be found in the link above) -
RSP720-3C, RSP720-3CXL, SUP720-3B,  SUP720-3BXL, SUP32
Hope this helps.
Brandon
351
