Webcast-Catalyst9k
Upgrade Catalyst 6500 SUP22 to IOS release SXF17a
Hi !
I would like to upgrade Catalyst 6000 supervisor 2/MSFC2 to release SXF17a.
I need an external flash card MEM-C6K-ATA-1-64M=.
Question: Is this flash card supported by the rommon on my SUP22 ?
Pls find show version, show module and remote command switch sh ver
best regards
/simon
Router#sh ver
IOS (tm) c6sup2_rp Software (c6sup2_rp-JK9SV-M), Version 12.2(14)SY1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 29-Jul-03 23:50 by kellythw
Image text-base: 0x40008BD8, data-base: 0x41ED6000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-JK9SV-M), Version 12.2(14)SY1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 40 minutes
Time since Router switched to active is 1 hour, 40 minutes
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootflash:c6k222-jk9sv-mz.122-14.SY1.bin"
cisco Catalyst 6000 (R7000) processor with 458752K/65536K bytes of memory.
Processor board ID SAL0725F27Y
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
1 Virtual Ethernet/IEEE 802.3  interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Router#sh mod
Mod Ports Card Type                              Model              Serial No.
  1    2  Catalyst 6000 supervisor 2 (Active)    WS-X6K-SUP2-2GE    SAL0721DRVB
  9   48  48 port 10/100 mb RJ45                 WS-X6348-RJ-45     SAD04310FDX
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0008.7dc9.5b7c to 0008.7dc9.5b7d   4.2   6.1(3)       7.5(0.94)    Ok
  9  0002.fc62.6f30 to 0002.fc62.6f5f   1.1   5.4(2)       7.5(0.94)    Ok
Mod Sub-Module                  Model           Serial           Hw     Status
  1 Policy Feature Card 2       WS-F6K-PFC2     SAL0721DVUE      3.3    Ok
  1 Cat6k MSFC 2 daughterboard  WS-F6K-MSFC2    SAL0725F27Y      2.5    Ok
Mod Online Diag Status
  1 Pass
  9 Pass
Router#
Router#remote command switch sh ver
Router-sp#
IOS (tm) c6s2p2_sp Software (c6s2p2_sp-SPV-M), Version 12.2(14)SY1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Compiled Wed 30-Jul-03 01:12 by kellythw
Image text-base: 0x40020BD8, data-base: 0x4091A000
ROM: System Bootstrap, Version 7.1(1)
BOOTLDR: c6s2p2_sp Software (c6s2p2_sp-SPV-M), Version 12.2(14)SY1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 41 minutes
Time since Router switched to active is 1 hour, 41 minutes
System image file is "bootflash:c6k222-jk9sv-mz.122-14.SY1.bin"
cisco Catalyst 6000 (R7000) processor with 112640K/18432K bytes of memory.
Processor board ID SAL0721DRVB
R7000 CPU at 250Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache
Router#
Everyone's tags (3)
Re: Upgrade Catalyst 6500 SUP22 to IOS release SXF17a
Hi Simon,
MEM-C6K-ATA-1-64M
Supported only on Supervisor Engine 2.
With software releases 7.5(1) and later, additional Flash PC card support was added as follows:
•64-MB ATA Flash PC card (MEM-C6K-ATA-1-64M=)—Only supported on Supervisor Engine 2. The device name is disk0: and the card requires ROMMON version 7.1(1) and later releases.
The MEM-C6K-ATA-1-64M(=) and MEM-C6K-FLC64M= Flash PC cards are not formatted. Although the cards appear to be formatted when first installed, you must format the cards to prevent possible data corruption.
Checked the IOS version release details:
New Features in Release 12.2(18)SXF17a
These sections describe the new features in Release 12.2(18)SXF17a, 19 Mar 2010:
New Hardware Features in Release 12.2(18)SXF17a
New Software Features in Release 12.2(18)SXF17a
None.
None.
Let me know your views on this.
podhillo
Hi Podhillo.
Thanks for your answer (I see that you are CSE at CiscoSystems)
Question: I not sure how to interpret the output from show version, show module and remote command switch sh ver !
remote command switch sh ver shows this:
Router-sp#
Do I have the right rommon then ? I am in doubt because http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_12667.pdf
says that sh module check rommon version (in thie case 6.1(3))
Router#sh mod
YOUR WROTE: Checked the IOS version release details:
If you wonder why we will upgrade the reason is this http://www.cisco.com/warp/public/707/cisco-sa-20090908-tcp24.shtml
Simon
Hi Simon,
The rom version is  6.1(3)and i see you are using 7.5(0.94) catos and below is the security advisory for catos fixed release.
Cisco CatOS Software
Affected Releases
First Fixed Release
7.x
7.6(24a)
8.x
8.7(2a)
Please open a TAC case if you need help to upgrade the sup2, keep a CSE with you before you proceed it will help.
Hope this helps!
podhillo.
388
