Upgrade from C2950G-48-EI to C2960G-48TC-L
Can a config from a  C2950G-48-EI be pasted into a new C2960G-48TC-L without issue?
The switches in question are in a cluster so I think at the very least those entries would need to be edited out.
I can post config if needed.
Thanks.
1 REPLY
Re: Upgrade from C2950G-48-EI to C2960G-48TC-L
James,
Unless its a cluster master, there should not be a problem in adding the new cluster member. I guess both the switches support the switch clustering in their IOS and should be easily configurable. You should be able to copy and paste the config easily.Check for any compatibility issues :
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_fx/configuration/guide/swclus.html
Cheers,
-amit singh
246
