Upgrade from CatOS to IOS on switches
Can I upgrade my Catalyst switches from CatOS to IOS? Is there somewhere I can find out?
Mike
1 ACCEPTED SOLUTION
Purple
Re: Upgrade from CatOS to IOS on switches
It depends on what supervisor you have , it must be at least a Sup II Plus to have ios . If it is only a sup II you cannot change it . If it is a Sup II plus it would have come with IOS . My guess is you have a 4500 chassis with a Sup II in which case you cannot upgrade it . You can do a show mod and post here and we can tell you .
Purple
Need to know what models you are talking. The only ones upgradeable would be the Cat 6500's , anything else is catos only . There are certain hardware requirements to do so also such as nvram and flash etc .....
But I have some 4506's that have IOS? Can't I upgrade my other 4500's?
Mike
Purple
That's it!!! I got it now. Thanks I must have over looked that. I have some supII and some supII+.
Mike
262
