Community Member
upgrade fwsm from 3.1(10) to 4.1(8)
I would like to upgrade fwsm from 3.1(10) to 4.1(8).
FWSM is install on 6509 and I just upgrade it to s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXH8b.
1. Can i upgrade fwsm directly form 3.1(10) to 4.1(8). Or i need to upgrade to 3.2(23) ?
2. How and what to backup (image)?
ok, i backup running config
3. upgrading procedure? I download image to tftp
so i just need to hit this?
copy tftp://10.1.200.11/asdm-622f.bin flash:asdm
copy tftp://10.1.200.11/c6svc-fwm-k9.4-1-8.bin flash:
and then reload? that's it?
additional information what did I try to do :-)
when i try to backup current image:
Firewall# dir
Directory of disk:/
8      -rw-  1882        12:39:46 Apr 21 2010  old_running.cfg
9      -rw-  1801        12:39:48 Apr 21 2010  admin.cfg
59748352 bytes total (59729920 bytes free)
Firewall# dir flas
Firewall# dir flash:
Directory of flash:/
2      -rw-  3963300     <no date>        asdm
1      -rw-  5898296     <no date>        image
3      -rw-  27076       <no date>        startup-config
No space information available
Firewall# copy flash:asdm tftp:
Source filename [asdm]?
Address or name of remote host [10.1.200.11]?
Destination filename [fwsm-running-confg]? asdm
Writing file tftp://10.1.200.11/asdm;int=inside...
3963300 bytes copied in 9.590 secs (440366 bytes/sec)
Firewall# copy flash:image tftp:
Source filename [image]?
Destination filename [fwsm-running-confg]? image
WARNING: The flash device is in use by another task.
Failed to open image in flash.
%Error writing to tftp://10.1.200.11/image;int=inside ()
Firewall#
Firewall# sh ver
FWSM Firewall Version 3.1(10)
Device Manager Version 5.0(3)F
Compiled on Mon 21-Apr-08 17:43 by fwsmbld
FWSM up 2 hours 43 mins
Hardware:   WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash STI Flash 8.0.0 @ 0xc321, 20MB
0: Int: Not licensed        : irq 5
1: Int: Not licensed        : irq 7
2: Int: Not licensed        : irq 11
The Running Activation Key is not set, using default settings:
Licensed features for this platform:
Maximum Interfaces          : 256
Inside Hosts                : Unlimited
Failover                    : Active/Active
VPN-DES                     : Enabled
VPN-3DES-AES                : Enabled
Cut-through Proxy           : Enabled
Guards                      : Enabled
URL Filtering               : Enabled
Security Contexts           : 2
GTP/GPRS                    : Disabled
VPN Peers                   : Unlimited
Serial Number: xxxx
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000
Configuration has not been modified since last system restart.
THX!
Ivan
1408
