Community Member
Upgrade IOS 3550 with Routes Port
Anyone know how to make a port on the 3550 a routed port instead of a switchport? I need to put an ip address on the interface to communicate with my TFTP server. It does not take the "no switchport" command. I check the technotes and no mention about turning it into a routed port.
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_example09186a0080169623.shtml#concept9
2 ACCEPTED SOLUTIONS
Re: Upgrade IOS 3550 with Routes Port
BTW, you don't necessarily need the interface to be L3. you can make it "switchport access vlan x", then create an SVI, interface vlan x and put the ip address on that interface vlan, it will work the same way as having a physical L3 port.
Purple
That is old so maybe it didn't have much functionality back then . All you have to do then is put an address on the vlan 1 SVI and give it a default gateway . If you are just tranferring it from your pc then set your pc address into the same address space make sure your tftpserver program is running and start your transfer.
conf t
no ip routing
int vlan 1
ip adresss xxx.xxx.xxx.xxx
no shut
exit
ip default-gateway xxx.xxx.xxx.xxx
address of the gateway off the subnet.
Hall of Fame Super Blue
Edit - apologies i didn't read your post fully.
Have you tried enabling routing first ie.
3550(config)# ip routing
int fa0/2
no switchport
ip address ....
Jon
Community Member
yes, I tried enabling ip routing, but the command did not work. Once I get the IP address on the interface, then the upgrade is easy.
David
What do you mean by "it did not work". When you entered that command what happened ?
What does a "sh ip route" show.
What version of IOS are you running ?
What does the interface config look like at the moment ?
Jon
I have a feeling this is not a 3550, can you send us a show version? 3550 on up are the only L3 switch that can do L3 functionality. Anything below like 29x0, 2900XL, 3500XL are strictly L2
Purple
Can you post a "show version " ?
Community Member
Sorry it took a while to get the information.
Attached is the show version, logging when I try to convert a switchport to a routed port, and the show tech. I have another 3550 sitting, which was loaded by cisco with a more recent image and it can do routing and will accept a the commands
without a fuss. Thanks a million.
Purple
conf t
no ip routing
int vlan 1
no shut
exit
Community Member
Thank you. It worked.
145
