08-08-2012 12:31 AM - edited 03-07-2019 08:12 AM
I own the Cisco switch,2950-24.
When power on,it says Crash fault with information showed below:
Signal = 10, Code = 0x1C, Uptime 00:00:12
r0: 00000000, AT: 00000000, v0: 80001800, v1: 00000000
a0: 80756370, a1: 00000040, a2: 80001840, a3: B8002CFC
t0: B8002CF8, t1: B8002CFC, t2: 10000000, t3: FFFF00FF
t4: 802F97E8, t5: 8072B514, t6: 80B90F88, t7: 00000009
s0: 80756364, s1: 80756370, s2: 80810000, s3: 40000000
s4: 80640000, s5: 00000001, s6: 80730000, s7: 80630000
t8: 00000006, t9: 00000000, k0: 00000000, k1: 00000000
gp: 8078F5A0, sp: 80B90F98, s8: 80640000, ra: 802E6964
EPC: 802F9904, ErrEPC: 6F053173, BadVA: 0xF3D7E200, SREG: 1000E703
Cause: 0x0000201C (code 7): Data Bus Error exception
-Traceback= 802F9904 802E6964 802CADDC 802CB200 802FB7A8 801E26A4 801E2760 80124
11C 80124338 801C3CFC 801C3CE8
after softreset,I got something similarly
Signal = 10, Code = 0x408, Uptime E
r0: 00000000, AT: 00000000, v0: 00000020, v1: 80730000
a0: 00000000, a1: 0000C100, a2: 00000000, a3: 80802BCC
t0: 801EA1EC, t1: 1000E101, t2: FFFFE1FD, t3: 00000000
t4: 1000E100, t5: 00000010, t6: FFFF00FF, t7: 10000000
s0: 00000002, s1: 00000001, s2: 80830000, s3: 80830000
s4: 0C800000, s5: 8064766C, s6: FFFFFFFE, s7: FFFFFFFD
t8: 10000000, t9: FFFFFFFF, k0: 00000000, k1: 00000000
gp: 8078F5A0, sp: FFFFFF60, s8: FFFFFFFB, ra: 802F9104
EPC: 00000000, ErrEPC: 6F053173, BadVA: 0x00000000, SREG: 1000E103
Cause: 0x00000408 (code 2): TLB (load or ifetch) exception
Then I search google.com and found the resolution of upgrating IOS.
I push mode button before power.Then I access into the CLI.I checked the files in the flash: and got these:
switch: dir flash:
Directory of flash:/
2 -rwx 2774747 <date> c2950-i6q4l2-mz.121-12c.EA1.bin
3 -rwx 269 <date> env_vars
4 -rwx 1216 <date> vlan.dat
7 drwx 832 <date> html
21 -rwx 110 <date> info
22 -rwx 110 <date> info.ver
3246080 bytes available (4495360 bytes used)
switch:
I delete bin,and got these:
switch: delete /force flash:/c2950-i6q412-mz.121-12c.EA1.bin
Are you sure you want to delete "/force" (y/n)?y
File "/force" not deleted -- permission denied
Are you sure you want to delete "flash:/c2950-i6q412-mz.121-12c.EA1.bin" (y/n)?y
File "flash:/c2950-i6q412-mz.121-12c.EA1.bin" not deleted -- no such file or dir
switch: delete flash:c2950-i6q412-mz.121-12c.EA1.bin
Are you sure you want to delete "flash:c2950-i6q412-mz.1211.bin" (y/n)?y
File "flash:c2950-i6q412-mz.1211.bin" not deleted -- no such file or directory
switch: delete flash:/c2950-i6q412-mz.121.12c.EA1.bin
Are you sure you want to delete "flash:/c2950-i6q412-mz.121.12c.EA1.bin" (y/n)?y
File "flash:/c2950-i6q412-mz.121.12c.EA1.bin" not deleted -- no such file or dir
I tried kinds of commands.Please give me a hand
08-08-2012 03:19 AM
Console into your switch and post the entire bootup sequence.
I would really like to see where it starts falling apart.
08-08-2012 07:36 PM
Leolaohoo,Thank you for paying attention to my problem!!The messages are the follow:
C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950-24 starting...
Base ethernet MAC Address: 00:0d:5e:14:02:c0
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 18 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4495360
flashfs[0]: Bytes available: 3246080
flashfs[0]: flashfs fsck took 6 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:/c2950-i6q4l2-mz.121-12c.EA1.bin"...#############################
File "flash:/c2950-i6q4l2-mz.121-12c.EA1.bin" uncompressed and installed, entry
point: 0x80010000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(12c)EA1, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 24-Nov-02 23:31 by antonino
Image text-base: 0x80010000, data-base: 0x80562000
Initializing flashfs...
flashfs[1]: 18 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 4495360
flashfs[1]: Bytes available: 3246080
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
Done initializing flashfs.
POST: System Board Test : Passed
=== Flushing messages (00:00:08 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
Signal 10, Exception code (0x001C)!
Frame 00: SP = 0x80B90F98 PC = 0x802F9904
Frame 01: SP = 0x80B90F98 PC = 0x802E6964
Frame 02: SP = 0x80B90FC0 PC = 0x802CADDC
Frame 03: SP = 0x80B90FE0 PC = 0x802CB200
Frame 04: SP = 0x80B91018 PC = 0x802FB7A8
Frame 05: SP = 0x80B91038 PC = 0x801E26A4
Frame 06: SP = 0x80B91050 PC = 0x801E2760
Frame 07: SP = 0x80B91078 PC = 0x8012411C
Frame 08: SP = 0x80B910A0 PC = 0x80124338
Frame 09: SP = 0x80B91178 PC = 0x801C3CFC
Frame 10: SP = 0x80B91190 PC = 0x801C3CE8
=== Crash Fault History ===
C2950 Software (C2950-I6Q4L2-M), Version 12.1(12c)EA1, RELEASE SOFTWARE (fc1)
Signal = 10, Code = 0x1C, Uptime 00:00:08
a0: 80752B50, a1: 00000040, a2: 80001840, a3: B8002CFC
t4: 802F97E8, t5: 8072B514, t6: 80B90F88, t7: 00000006
s0: 80752B44, s1: 80752B50, s2: 80810000, s3: 40000000
t8: 00000004, t9: 00000000, k0: 00000000, k1: 00000000
EPC: 802F9904, ErrEPC: 0D051015, BadVA: 0x90040220, SREG: 1000E703
Booting after a softreset ...
point: 0x80010000
executing...
cisco Systems, Inc.
(fc1)
=== Flushing messages () ===
Signal 10, Exception code (0x0408)!
Frame 00: SP = 0xFFFFFF60 PC = 0x802F9104
Frame 01: SP = 0x00000000 PC = 0x802F9104
EPC: 00000000, ErrEPC: 0D051015, BadVA: 0x00000000, SREG: 1000E103
-Traceback= 0 802F9104
It Stoped here.The bin 12.1(12c)EA1,just softreset twice.
08-08-2012 07:47 PM
It's looks like it's dead but you're getting a "Signal 10" error message which also means an IOS bug. Try uploading a different IOS version.
08-08-2012 07:55 PM
I have tried but it didn't work.Please see my reports below which act as the replies to Alessio.
08-08-2012 04:22 AM
Hi QiNie,
did you try to Xmodem a new IOS in your flash? It takes time but it should work... However i would be worried about the last row:
Alessio
08-08-2012 07:47 PM
Thank you, Alessio,I have tried this method.I download the BIN,C2950 EI AND SI IOS IMAGE,from here :
I Send the c2950-i6q4l2-mz.121-22.EA14.bin to flash: with Xmodem Protocol,boot from it but failed.And the Crash Fault History said something about Bus error, which just like the old bin done.Then the swith began to softreset from the old bin again and again.....
Is it a hardware problem?
I deleted c2950-i6q4l2-mz.121-22.EA14.bin very easily.But the old bin still con't be removed.
08-08-2012 08:02 PM
Another thing, you need to FORMAT the flash first before you load IOS version EA14 back. If you don't format your flash (via ROMmon), you will not have enough space to put the IOS in.
08-08-2012 08:21 PM
When I attempted to send the EA14 there,I checked the space is very enough.So I put it in and run it then failed.
But format it must can delete the old one.I will do this.
