03-26-2012 11:29 AM - edited 03-07-2019 05:47 AM
Hi all,
Does anybody know how to upgrade IOS in switch 6500 connect in VSS from 12.2(33)SXI IOS to
12.2(33)SXJ?
Thanks.
03-26-2012 12:38 PM
please try a search on the cisco.com site. There is a guide.
03-26-2012 02:16 PM
This is how I've done it ...
1. Copy the IOS to primary supervisor card using the command "copy tftp:
2. Copy the IOS to the SECONDARY supervisor card using the command "copy tftp:
3. Remove the old boot variable string using the command "NO boot system flash sup-bootdisk:OLD_IOS.bin"
4. Add the new IOS file to the boot variable string using the command "boot system flash sup-bootdisk:NEW_IOS.bin"
Hope this works for you.
Please don't forget to rate our useful posts. Thanks.
Message was edited by: Leo Laohoo
03-27-2012 12:02 PM
ok, thanks.
12-06-2013 05:57 AM
Dear Leo,
Can you send me the link for IOS upgradation procedure for 6500 (6509 & 6513).
12-06-2013 06:25 PM
I think this link may help: IOS upgrade on Catalysts 6000/6500 Series
