Community Member
Upgrade IOS on VSS pair
I have 2 6513-E switches with Supervisor 2T modules.
They are in a VSS-SSO pair, and I need to upgrade the IOS from 15.1.1(SY) to the latest.
The documentation I am seeing does not take into account the E chassis or the Supervisor 2T, so I am a bit confused on how this is done (there is no slavedisk, etc.)
Anyone have an upgrade procedure for this setup?
2 ACCEPTED SOLUTIONS
Silver
Re: Upgrade IOS on VSS pair
Hi Colin,
The upgrade should be the same as any other upgrade on a VSS setup, the fact that you have SUP2T and  E chassis should not change the procedure.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/15.0SY/configuration/guide/virtual_switching_systems.html#wp1341260
Table 4-1     VSS Hardware Requirements
Hardware
Count
Requirements
Chassis
All chassis supported in Cisco IOS Release 15.0SY support VSS mode.
Note The two chassis need not be identical.
Supervisor Engines
Either two VS-SUP2T-10G or two VS-SUP2T-10G-XL supervisor engines.
The two supervisor engines must match exactly.
Switching Modules
  2+
VSS mode support as shown in the Release Notes.
VSS mode does not support 61xx switching modules. In VSS mode, unsupported switching modules remain powered off.
Hope this helps.
VIP Super Bronze
You got it.  That is the easiest way to do upgrade a VSS pair specially if you effort to have 1/5 hour of down time.  Copy the image to both bootdisk and salvebootdisk, set your boot variable, save the config and reboot.
You will be back in business is less than 15 minutes. Of course, you want a longer outage window just in case.
Silver
Hi Colin,
Hardware
Count
Requirements
Chassis
Supervisor Engines
Switching Modules
  2+
Hope this helps.
VIP Super Bronze
The primary VSS device is bootdisk and for the stand-by it is slavebootdisk.
What the output of dir flash?
Community Member
Ah OK
So I can copy the new image into both the bootdisk: and slavebootdisk:, modify the boot system statement, and the reload the chassis?
It will be done after-hours, so I can have some downtime.
VIP Super Bronze
Community Member
Perfect. thanks for the help guys.
VIP Super Bronze
Glad to help.  Thanks for the rating
425
