Upgrade ios sup 720
i have tftp new ios to sup-bootflash:
changed boot var and switch still loads to old ios.  What am i missing?
1 REPLY
Hall of Fame Super Blue
Re: Upgrade ios sup 720
When you say changed boot var have you changed in the running config the "boot system ..." string ie.
6500(config)# boot system flash
if you have an existing boot system image in the running config then you need to make sure the new image is first in the running config.
Also check your configuration register.
Jon
272
