05-28-2012 09:19 AM - edited 03-07-2019 06:56 AM
Good Day,
We have upgraded our gateway router from a Cisco Linksys RVL200 to a Cisco 861, this is a big jump from a GUI driven system to IOS CLi and i'm having issue finding my feet. I tried the Cisco CP system but it didn't work so I'm going to configure it with IOS commands. I wish to replicate the current configuration on the 200 with the following setup, can someone help with the following problems:
Solved! Go to Solution.
05-29-2012 08:26 AM
Hi Alastair,
The client identifier is formed by concatenating the media type and the MAC address. For example, the Microsoft client identifier for Ethernet address b708.1388.f166 is 01b7.0813.88f1.66, where 01 represents the Ethernet media type.
So you can build static mappings without connecting devices, if you know their MAC addresses. The following guide could be helpful to do that:
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iad_dhcp_svr_cfg.html#wp1117976
Kind Regards,
Ivan
**Please grade this post if you find it useful.
05-28-2012 12:19 PM
if you have only ONE LAN then this is your config:
ip dhcp pool USERS
network x.x.x.x / prefix
dns-server x.x.x.x
default-router x.x.x.x
if you have inter-vlan routing, L3 devices like layer 3 switches and other routers in the way, u have to set ip helper-address on their interfaces.
this Link could be a help:
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfdhcp.html#wp1001001
plz Rate if it helped.
Soroush.
05-28-2012 12:32 PM
Hi Alastair,
You have to configure the following kind of configuration:
ip dhcp pool pool10
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
interface GigabitEthernet0/1.10 //this is for connected vlan 10
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
Note that if you have multiple pools, router chooses the one which "default router" IP corresponds the IP address of interface the DHCP client is connected to.
E.g. GigEth0/1.20 would get an IP from pool20 instead of pool10.
ip dhcp pool pool20
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 10.10.20.1 255.255.255.0
Kind Regards,
Ivan
05-29-2012 06:19 AM
thank you guys fr your replies, do you have any information on the generation of client-identifiers
05-29-2012 06:27 AM
Hi Alastair,
You can determine the client identifier by using the debug ip dhcp server packet command. In the following example, the client is identified by the value 0b07.1134.a029.
Router# debug ip dhcp server packet
DHCPD:DHCPDISCOVER received from client 0b07.1134.a029 through relay 10.1.0.253.
DHCPD:assigned IP address 10.1.0.3 to client 0b07.1134.a029.
PS: Please do rate the posts that were useful.
Kind Regards,
Ivan
05-29-2012 06:30 AM
Ivan, would I need to plugin all the clients then run that command to find the c-id or could I workout the c-id in advanced.
05-29-2012 06:44 AM
Yes, you would need to connect clients for client-id to generate those DHCP packets to server. After all, it is client who is providing its client ID to server, not the way around - so without client there is no ID. Also, in some cases the dhcp packet from client may not even have Client ID value.
But typically ClientIDs are most likely to be the client MAC addresses, so if you know those - you can use them without connecting the clients.
By the way, if the clients were successfully provided address by DHCP, you can check the ClientID in "show ip dhcp server bindings" command too (that works after the binding was made).
Kind Regards,
Ivan
05-29-2012 07:53 AM
Thanks Ivan, my questions are lead by the need to create static hosts on DHCP and i have a list of MAC addresses but if i want to create the static routes i would need a client-id aswell
05-29-2012 08:26 AM
Hi Alastair,
Kind Regards,
Ivan
