01-07-2009 08:01 AM - edited 03-06-2019 03:17 AM
Is there a procedure to upgrade 3750 FE stacks to 3750 GE without losing the config?
I have a stack of 4 3750's, 1 (Master) is GE, the other 3 are FE switches. I want to replace the FE switches within the stack with gigabit switches. Is there an automated way to do this without manually re-configuring the stack?
I know you can replace "like" switches and the stack will rebuild its self, I was wondering if I can replace a FE switch with a GE switch and have the stack rebuild automatically.
01-07-2009 09:01 AM
I believe there is no way to replace a switch in a Stack without losing the Config.
01-07-2009 09:42 AM
You could save your configuration out to a text file. Alter the config by doing find replace and change all the Fast Ethernets to Gigabit Ethernet
Once you install your new switches
Paste your new config back into the switch.
That would take care of that part of your configuration.
Hopefully this helps some
01-07-2009 10:31 AM
Thanks, That is what I had planned, I was hoping someone knew of a quicker way so I'm not down rebuilding very long.
