Upgrading a 4506 from a Sup7L-E to a Sup8
Is there a documented procedure to upgrade from a Sup7L-E to a Sup8 on a 4506?  I want to make sure I have everything covered from any power issues to the most efficient way to migrate the config.
1 ACCEPTED SOLUTION
Silver
Hi,  There is no specific
 There is no specific documentation for such a procedure, below you can find the installation notes for the SUP-8-E and the configuration guides:
Cisco Catalyst 4500 Series Switches Configuration Guides:
http://www.cisco.com/c/en/us/support/switches/catalyst-4500-series-switches/products-installation-and-configuration-guides-list.html
Installation and Configuration Note for the Cisco Catalyst 4500 E-Series Supervisor Engine 8-E:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_29676.html
Hope this helps.
1 REPLY
Silver
Hope this helps.
36
