Upgrading from 3750 to 3750G question
If i am upgrading a switch from a 100 mg to a gig switch, is there anything i need to do besides to load the configs from the regular 100mg switch?
6 Replies 6
Mark Yeates
Level 7
Level 7
There really isn't any difference in the switch besides the port speeds. You shouldn't have to do anything besides copy and paste the config into the new 3750G switch.
HTH,
Mark
Thank you Mark!
Dustin
You will have to do a search and replace for 'FastEthernet' to 'GigabitEthernet' in the config file though :o)
Andy
how can you do that....just open the file up in notepad and do it? or?
Sorry I kinda forgot about doing that... In word pad do a replace FastEthernet with GigabitEthernet will change it. Also there is one additional thing I forgot is your SFP ports will change also to Gi1/0/49-52 since all ports on the switch are gigabit.
Mark
P.S. Thanks Andy for pointing that out!
Thank you! I really appreciate all your help!
