Upgrading From WS-X6K-SUP1A-2GE to SUP720
WS-X6K-SUP1A-2GE is running CatOS and i am going to change to SUP720 which will be running IOS . How do i go ahead with this activity ?
regards
Neo
Re: Upgrading From WS-X6K-SUP1A-2GE to SUP720
Hi Neo,
First make sure of 2 things that your chassis in 6500 and also you have high speed fan tray which is required for sup 720.
Also you have to take your your sup1A first and and then insert the new sup 720 and by default sup 720 comes with CATOS if you have not specifically ordered for NATIVE IOS preloaded then you can check this link to convert from CATOS to Native IOS
http://www.cisco.com/warp/customer/473/81.html#conv_720
Ankur
*Pls rate helpfull post
Hi Neo,
In addition to Ankur's post I would like to tell you the specific slot requirements for Sup720 on Cat6500 chsssis. Which chassis do you have ?
Here is the table
6503/6504 slot1
6506 Slot5 and Slot6
6509 Slot5 and Slot6
6513 Slot7 and Slot8
Please make sure that you have the Sup720 plugged into one of the slot depending on the chassis, otherwise the Sup will not power up.
HTH,Please rate if it does.
-amit singh
159
