Upgrading IOS and Netflow
I am new to cisco and am trying to get netflow working.
when i log into my router and do a show version i get the following information
_________________________________________
WASHINGTON#sh version
IOS (tm) C2600 Software (C2600-IS-M), Version 12.1(5)T10, RELEASE SOFTWARE (fc2
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 08-Aug-01 08:52 by ccai
Image text-base: 0x80008088, data-base: 0x8101AD48
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
WASHINGTON uptime is 9 weeks, 5 days, 16 hours, 10 minutes
System image file is "flash:c2600-is-mz.121-5.T10.bin"
cisco 2620 (MPC860) processor (revision 0x600) with 36864K/4096K bytes of memory
Processor board ID JAD05390HV7 (1163454854)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Do i need to upgrade my IOS? if so how do i go about getting an upgrade for my IOS?
or can anyone tell help me out in setting up netflow on this router.
If you need config please let me know so that i can post.
Thank you in advance
Re: Upgrading IOS and Netflow
Your IOS supports netflow
These configurations will help you get this going
interface
ip route-cache flow
this needs to be configured under all the interfaces
ip flow-export version 5
ip flow-export destination
Narayan
Thank you for getting back to me
Here is the FastEthernet configuration that is currently set
_____________________________________________
interface FastEthernet0/0.1
description Data
encapsulation dot1Q 1 native
ip address 10.43.80.1 255.255.240.0
no ip route-cache
no ip mroute-cache
bridge-group 1
when i go to enter the ip route-cache flow onto this interface i get the following message
WASHINGTON#config t
Enter configuration commands, one per line. End with CNTL/Z.
WASHINGTON(config)#in
WASHINGTON(config)#interface fa
WASHINGTON(config)#interface fastEthernet 0/0.1
WASHINGTON(config-subif)#ip rou
WASHINGTON(config-subif)#ip route-cache flow
% Invalid input detected at '^' marker.
Am i doing anything wrong? or does something else have to be setup first?
Thanks again for your help
Hmm it could be that you are enabling it on a subinterface. Not too sure if your version of IOS supports this. I did find the link below explaining this, but I do not have personal experience with a sub-interface. I may need to lab that one up and see.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ft_nfsub.html#wp1035352
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hnf_c/ch05/nfb_bicf.htm#wp1046037
Sorry here is my router config
WASHINGTON#sh run
Building configuration...
Current configuration : 3308 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname WASHINGTON
logging buffered 4096 debugging
logging rate-limit console 10 except errors
enable secret 5
clock timezone EDT -5
clock summer-time EDT recurring
ip subnet-zero
no ip finger
ip tcp synwait-time 5
no ip domain-lookup
class-map match-all Voice
match ip dscp 46
policy-map Policy1
class Voice
priority 500
class class-default
fair-queue
isdn switch-type basic-dms100
call rsvp-sync
bridge crb
buffers middle permanent 1500
buffers middle max-free 1600
buffers middle min-free 1400
interface Loopback1
description Washington Loppback Interface
ip address 10.254.15.1 255.255.255.224
description Washington Local Area Network
no ip address
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
description Data
no ip route-cache
no ip mroute-cache
bridge-group 1
interface FastEthernet0/0.10
description Voice
encapsulation dot1Q 10
ip address 192.168.6.1 255.255.255.0
no ip route-cache
no ip mroute-cache
interface FastEthernet0/0.105
description VPN link to Checkpoint
encapsulation dot1Q 105
ip address 10.254.5.10 255.255.255.0
no ip route-cache
no ip mroute-cache
shutdown
interface Serial0/0
description T1 to RANDOLPH
bandwidth 1536
ip address 10.252.5.134 255.255.255.252
no ip route-cache
no ip mroute-cache
service-policy output Policy1
service-module t1 timeslots 1-24
bridge-group 1
interface BRI0/0
description Backup ISDN to RANDOLPH
no ip address
encapsulation ppp
shutdown
dialer rotary-group 1
no cdp enable
interface Dialer1
ip address 192.168.253.6 255.255.255.252
encapsulation ppp
shutdown
dialer in-band
dialer idle-timeout 100
dialer hold-queue 10
dialer load-threshold 1 outbound
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname RANDOLPH
ppp chap password xxx
ppp multilink
router eigrp 1
passive-interface Loopback1
network 10.0.0.0
network 192.168.6.0
no auto-summary
eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 10.43.80.3 210
no ip http server
logging trap debugging
logging 10.43.144.26
logging 10.43.144.78
dialer-list 1 protocol ip list 101
snmp-server community cisco RW
snmp-server community Nagio5 RO
snmp-server chassis-id WASHINGTON
bridge 1 protocol ieee
bridge 1 route ip
dial-peer cor custom
banner login ^C
* Unauthorized Access is Prohibited *
* Access is restricted to authorized Personel ONLY *
* Unauthorized access is Punishable by LAW *
^C
line con 0
exec-timeout 5 0
password xxx
login
transport input none
line aux 0
password xxx
login
modem InOut
transport input all
line vty 0 4
exec-timeout 240 0
password xxx
logging synchronous
login
scheduler allocate 4000 6000
end
WASHINGTON#
ip route-cache flow command is applicable only on the main interface and will track the flow of all the subinterfaces
IOS introduced the support of netflow on the subinterfaces using the command ip flow ingress & ip flow egress but i am not sure whehter your IOS supports this feature
Narayan
Thank you,
I've added the following commands to my router onto interface fastethernet 0/0
WASHINGTON#config t
WASHINGTON(config-if)#ip route
WASHINGTON(config-if)#ip route-cache flow
WASHINGTON(config-if)#exit
WASHINGTON(config)#ip fl
WASHINGTON(config)#ip flow-ex
WASHINGTON(config)#ip flow-export des
WASHINGTON(config)#ip flow-export destination 10.43.144.85 2055
WASHINGTON(config)#ip flow-export so
WASHINGTON(config)#ip flow-export source fa
WASHINGTON(config)#ip flow-export source fastEthernet 0/0
WASHINGTON(config)#ip flow-export ver
WASHINGTON(config)#ip flow-export version 5
WASHINGTON(config)#ip flow-c
WASHINGTON(config)#ip flow-cache tim
WASHINGTON(config)#ip flow-cache timeout ac
WASHINGTON(config)#ip flow-cache timeout active 5
WASHINGTON(config)#ip flow-cache timeout in
WASHINGTON(config)#ip flow-cache timeout inactive 15
WASHINGTON(config)#sn
WASHINGTON(config)#snm
WASHINGTON(config)#snmp-server ifindex persist
WASHINGTON(config)#^Z
WASHINGTON#write
Once i added these my network seemed to stop working. my computers could not connect to my domain controllers back to my main site.
my phones could not connect to the call server back at my main site.
but i could ping all eqiupment, routers, servers, switches, but not my phones since they were not registering back to the main site.
What i am i doing wrong? is this normail?
could it be due to the ip flow-cache timeout active 5? should this be set longer?
any help would be appreciated.
Hello Again,
I've tried using ip flow ingress on the sub interface and i am not allowed to make this entry. when i do my research i see that i need ios 12.2 or higher and i only have 12.1.
how do i go about upgrading my ios? i am new to cisco and not sure on the steps i need to take to upgrade my ios so that i can support netflow correctly.
You need to have some type of support contract to be able to log in with your cco and download the ios you need. After you have the ios you then need to put it on your flash and change your boot statement. Probably the more complicated task will be obtaining the ios.
http://www-europe.cisco.com/univercd/cc/td/doc/product/access/acs_fix/800/800swcfg/upg_ios.htm
213
