06-03-2014 12:15 PM - edited 03-07-2019 07:37 PM
I have a modular 1720 with IOS y-mz-12.1(5)T12 on it. I think is very old IOS, I know that router not support the newer IOS, but I want upgrade it a bit for CCENT. Any recommendations?
C 1720 32/8
I'm very new on this...
Solved! Go to Solution.
06-15-2014 02:45 PM
You can still accomplish a lot with 12.2 depending on what you are looking for :) If you need 15.x and newer you will need to buy something new. You can also consider trying out packet tracer and/or GNS3 ;)
Thank you for rating helpful posts!
06-03-2014 03:08 PM
With that old of a router I would recommend that you download and install the latest code supported on your platform. Keep in mind the RAM and FLASH requirements selecting the version and code.
06-04-2014 04:01 PM
But i saw I can't install more that IOS12.2 mmmmm. Then maybe is time for put it in the trash. Thank for the Help ;)
06-04-2014 04:00 PM
06-15-2014 02:45 PM
