Community Member
Upgrading to Navtive IOS
I'm trying to upgrade my Supervisor Engine II w/ MSFC to Native IOS. I'm receiving the error below after issuing the following command from the rommon> of the RSM.
boot sup-slot0:imagename.bin
*** System received a Software forced crash ***
signal= 0x17, code= 0x41cb0000, context= 0x41ccfab4
PC = 0x402955cc, Cause = 0x1820, Status Reg = 0x34018002
Does anyone have a clue as to why this is happening? I get this same error on two different supes.
Thank you,
Scott
Silver
Re: Upgrading to Navtive IOS
Probably there is a problem with the image. Re-download the image from Cisco website and then upload to the SUP. Make sure you download the version which is compatible with your hardware.
Community Member
Thank you for your response; I re-downloaded the image, formatted the flash card, and copied the newly downloaded image onto it. I get the same results when trying to upgrade; I'm positive this is the correct image for my hardware:
Image:
s222-adventerprisek9_wan-mz.122-18.SXF4.bin
Hardware:
WS-X6K-SUP2-2GE
WS-F6K-PFC2
WS-F6K-MSFC2
Silver
The second troubleshooting step is to remove all cards from the switch and try to boot. If the same problem happens I suggest opening a case with Cisco to troubleshoot this issue.
Let me know what is the result,
140
