02-21-2008 10:54 AM - edited 03-05-2019 09:17 PM
i have a network that consists of 2950.
I'm using a crossover cable to connect a port from the 2950 and connect the other end to a 3550 and make the new switch part of the vlan that's configured on the 2950.
For some reason, i can't get it to work, anybody know why??
thx
Solved! Go to Solution.
02-21-2008 11:03 AM
Can you provide the configs of each? What did you setup to make it work? Did you setup the link as a trunk? Did you setup VTP? etc.
02-21-2008 11:03 AM
02-21-2008 11:15 AM
Hi sdrossen2,
I found my problem, the 2950 port was engaging in a trunk mode.
problem fixed.
thx for your help.
