Webcast-Catalyst9k
Silver
uplink ports in sup II +
hello
using 2 SUP II+ in a single 4507R. each SUP contains 2 GBIC. but one sup is active and the second is standby.
are the 4 GBIC active or just the 2 belonging to the actif SUP ?
thanks
1 ACCEPTED SOLUTION
Re: uplink ports in sup II +
Hi Friend,
Using a sup II+ and sup 4 according to the restrictions only Gig1/1 and Gig2/1 Gigabit Ethernet interfaces are available and the Gig1/2 and Gig2/2 uplink ports are unavailable.
If the redundant supervisors are Sup V {WS-X4516 } active and standby installed in the same chassis, the four uplink ports (Gig1/1, Gig2/1, Gig 1/2, and Gig2/2) are available.
Check this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_25a/conf/rpr.htm#wp1097897
Ankur
*Pls rate all helpfull post
1 REPLY
Hi Friend,
Check this link
Ankur
132
