uplink
hello!
its unpossible to run spanning-tree uplink fast on the Ds-Switches,right?
10xs
Re: uplink
Spanning uplink fast is run on switches which are dually connected to 2 distribution or core switches of which one is a root. It helps in reducing the delay in converging the STP topology when the root port has failed. This reduces the convergence time for 40 sec to just 1 sec.
Refer this link:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a0080094641.shtml#backinfo
Ifyou are asking about running the feature on trunks between 2 DS siwtches which are root & backup root, then you need the backbonefast feature.
Refer this link:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800c2548.shtml
hope that clarifies.
pls rate all helpful posts.
Re: uplink
Ali,
Uplinkfast can be enabled even in Distribution switches but mostly the implementation is done in such a way that the DS's are the roots of soanning tree and hence have all ports in designated state.
Uplinkfast helps only those switches when they have a blocked port and there is a failure on the root port which is mostly on the access switch connecting to the core/Distribution
Narayan
Re: uplink
10xs Freinds
160
