Uplinks on WS-X45-Sup6L-E supervisor engine
With the WS-X45-Sup6L-E supervisor engine, is it possible to use one of the uplink ports with the X2 optics for 10G speeds and the other port with a Cisco Twin Gigabit ?
Hey,It is not supported due
Hey,
It is not supported due to hardware limitation. Check the link below:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/44sg/configuration/guide/Wrapper-44SG/sw_int.html#wp1084402
HTH.
RS.
i have made some
i have made some configuration that make me supose that it is posible
CAT4K-HUB01_10GB_TEP#sh hw-module module 1 port-group
Module Port-group Active                         Inactive
   1        1     Gi1/3-4                        Te1/1
   1        2     Te1/2                          Gi1/5-6
CAT4K-HUB01_10GB_TEP#sh interf status module 1
Port      Name               Status       Vlan       Duplex  Speed Type
Te1/1     HUB01-PO1-CTC-20GB inactive     1            full    10G No X2
Te1/2     HUB01-PO1-CTC-20GB notconnect   1            full    10G No X2
Gi1/3     LIBRE              notconnect   1            full   1000 No Gbic
Gi1/4     LIBRE              notconnect   1            full   1000 No Gbic
Gi1/5     LIBRE              inactive     1            full   1000 No Gbic
Gi1/6     LIBRE              inactive     1            full   1000 No Gbic
My bad, I misinterpreted the
My bad, I misinterpreted the question.
Its fully supported. You may use the 10G and 1G on different port-groups.
RS.
195
