02-14-2008 02:13 PM - edited 03-05-2019 09:10 PM
I attempting to upload IOS to a FLASH drive on Cisco router 2821 via console.
But I'm getting a failure message:
"ARP: address resolution for 216.214.47.112 timed out.
ARP failed with failure code 1. TFTP transfer aborted."
Here is the input:
IP_ADDRESS=216.214.47.70
rommon 7 > IP_SUBNET_MASK=255.255.255.0
rommon 8 > DEFAULT_GATEWAY=216.214.47.1
rommon 9 > TFTP_SERVER=216.214.47.112
rommon 10 > TFTP_FILE=c2800nm-spservicesk9-mz.124-17a.bin
rommon 11 > tftpdnld
And here is the output:
IP_ADDRESS: 216.214.47.70
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 216.214.47.1
TFTP_SERVER: 216.214.47.112
TFTP_FILE: c2800nm-spservicesk9-mz.124-17a.bin
TFTP_VERBOSE: Progress
TFTP_RETRY_COUNT: 18
TFTP_TIMEOUT: 7200
TFTP_CHECKSUM: Yes
TFTP_MACADDR: 00:15:63:8f:4a:c0
GE_PORT: Gigabit Ethernet 0
GE_SPEED_MODE: Auto
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: y
TFTP: Operation terminated prematurely.
Please advise.
Thank you,
Vlad.
Solved! Go to Solution.
02-22-2008 09:53 AM
Vlad
I believe that the suggestions made by Vaibhav are very good - you should get into privilege mode, then you should format the flash, and if that is successful then you should copy tftp flash to get the image from the TFTP server onto the flash.
Rick
02-22-2008 11:59 AM
Yes, xmodem -cry worked. Now I have a user ID and password prompts. Could you remind me what's initial Cisco credentials. And also I'm not sure where is OS located now and if I can reboot the router.
Thank you,
Vlad.
02-22-2008 12:03 PM
I figured out the credentials :-) cisco/cisco
But still not sure if I can reload the router.
Vlad.
02-22-2008 12:59 PM
Vlad
Have you taken the steps to format the flash and to copy the IOS from the TFTP server into flash? If you have not done these things then it will create the problem again if you reload the router.
A simple way to answer this question is that if you do show flash and it displays an image file in flash then it is ok to reload. If it does not display an image file in flash then it is not ok to reload.
Rick
02-28-2008 10:20 AM
Rick,
I was trying to load IOS from TFTP server to flash, but getting an error message. I loaded a few different files with IOS to TFTP server, but still could not copy them to flash. I tried both connections console and ethernet (crossover cable)conectiions.
Here is an input and output:
Username: cisco
Password:
halsted_line01#enable
halsted_line01#copy tftp flash
Address or name of remote host []? 10.10.10.2
Source filename []? c2800nm-entbasek9-mz.124-10.bin
Destination filename [c2800nm-entbasek9-mz.124-10.bin]?
Accessing tftp://10.10.10.2/c2800nm-entbasek9-mz.124-10.bin...
%Error opening tftp://10.10.10.2/c2800nm-entbasek9-mz.124-10.bin (No such file o
r directory)
halsted_line01#
Vlad.
02-28-2008 10:40 AM
Vlad
The output that you posted here indicates some issue with the TFTP server and not necessarily any problem with the router. The error indicates that the TFTP server could not find the file that you told it to load. The common causes of the TFTP server not finding the file are that there was something in the file name misspelled (what is in the output looks reasonable but I can not be certain that it is right) or that the file is not in the directory that the server is looking in. You might want to check how the TFTP server is configured, especially for what directory it is looking in for the file that it will serve. Many TFTP servers can be configured to specify a directory if you do not want to use what is its default directory. So you might want to see where it is looking and whether the image file is in that directory.
Rick
02-28-2008 11:46 AM
Rick,
that's great! I found a root directory of TFTP server (for some reason I did not see it in windows explorer) in TFTP server manager and copied IOS.
Thanks a lot!
Sincerely,
Vlad.
02-28-2008 11:50 AM
Vlad
I am glad that you could find the directory and were able to copy the IOS image file to the router.
Rick
02-28-2008 02:12 PM
Rick,
now I have new issue:-(. I decided to copy to flash another release of Cisco IOS. And here is a result:
halsted_line01#copy tftp: flash:
Source filename []? c2800nm-spservicesk9-mz.124-18.bin
Destination filename [c2800nm-spservicesk9-mz.124-18.bin]?
Accessing tftp://10.10.10.2/c2800nm-spservicesk9-mz.124-18.bin...
Erase flash: before copying? [confirm]y
Erasing the flash filesystem will remove all files! Continue? [confirm]y
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeeeeeeeeeeeeeeeeeeeeeeeee ...erased
Erase of flash: complete
Loading c2800nm-spservicesk9-mz.124-18.bin from 10.10.10.2 (via GigabitEthernet0
/0): !!
%Error copying flash:c2800nm-spservicesk9-mz.124-18.bin (No space left on device
halsted_line01#
I deleted existing IOS and sh flash command indicates that there is no files on the flash.
Any thoughts?
Vlad.
02-28-2008 02:46 PM
Vlad
It appears that the new image that you attempted to copy requires more flash memory than you have available on the router. In the process of the copy the router erased the content of flash but then the copy of the new file failed. So now there is no image in flash.
The good news is that the router can continue to run with no image in flash. Having an image in flash only becomes an issue when the router needs to boot. So for the time being - do NOT initiate any reboot of the router.
While the router is running you should be able to do a normal copy of the IOS image file that you are running (the one that was in flash before you erased it to make room for the new one). Once you get the image back into flash there should not be a problem.
If the router should happen to boot before you get an image into flash it would go to rommon - as it was when this discussion started. In that case you would need to use tftpdnld or xmodem to copy the image file as you did earlier in this discussion.
Rick
02-28-2008 03:20 PM
Rick,
that I was trying to do. I was copying IOS from TFTP to flash. Did not work.
Can I copy IOS that is currently in NVRAM to the flash w/o involving TFTP?
Flash (64 MB which should enough for IOS)has no files. It is empty.
Should I format CF?
Vlad.
02-28-2008 05:39 PM
Vlad
I do not see any reason to format the CF. If I understand right you had an IOS image file in the CF and then it was erased. That is not necessarily a reason to format the CF. (of course if you do format the CF I do not believe that it will harm anything)
If I understand right you had several IOS image files on the TFTP server. I suggest that you use the version that was on the CF at one point and copy it to flash again.
Rick
