Community Member
Urgent help. Etherchannel
I have created a port channel between 2 switches
int fa0/1 and fa0/2
as the following
int range fa0/1-2
switch mode access
switch acce van 10
channel-gr 10 mode on
Switch A
Created vlan 10
ip addres 1.1.1.1 255.255.255.0
Switch B
Created vlan 10
ip addres 1.1.1.2 255.255.255.0
but as soon as I connect the cables into the Fa0/1 and Fa0/2 on both switch it comes up and then goes down and stops working so I cannot ping 1.1.1.1 or 1.1.1.2.
What am I doing wrong?
These are Cat 2960.
Community Member
Re: Urgent help. Etherchannel
Etherchannel cannot be created across different switches unless you use Catalyst 3750 X-stack. Across different ports on the same stack of switches.
Community Member
These are Cat2960s and not different switches. Ok, maybe I have to use a cross over cable as they are switch to switch
Community Member
What i meant different switches are different physical switches irregardless of models.
Yes you can use cross cable to create VLAN trunk or L3 links.
But if you want to use etherchannel across different physical switch, it cannot be done unless you use Catalyst 3750 X-stack.
Purple
If you are using straight thru cables and letting mdix correct the pinouts then you "cannot" hardcode the speed and duplex on the ports , they must be left as auto for this to work.
Community Member
YOu will need to use cross over cables unless you can alter the MDI-MDIX settings. You should also fix the speed/duplex to 100/full on all ports.
Hi Ade,
1. The best is to use crossover cables.
2. Please look at the speed and duplex settings of the ports in question with the "show interface fa0/1" and "show interface fa0/2" commands on both switches.
If they are not the same, then issue the "speed 100" and "duplex full" commands in interface config mode on both ports on both switches.
3. Did you configure the port-channel on both switches with the same commands?
Cheers:
Istvan
181
