08-27-2010 08:44 AM - edited 03-06-2019 12:41 PM
Dear Experts,
We are using WS-C3750G-12S-S now we need to PBR in this switch.
Current IOS : flash:c3750-i9-mz.122-20.SE3/c3750-i9-mz.122-20.SE3.bin
I am not sure , it is support PBR of this switch or not
IOS (tm) C3750 Software (C3750-I9-M), Version 12.2(20)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Sun 17-Oct-04 01:18 by antonino
Image text-base: 0x00003000, data-base: 0x00997458
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(19r)EA1b, RELEASE SOFTWARE (fc2)
switch-3750-1 uptime is 2 weeks, 5 days, 13 hours, 5 minutes
System image file is "flash:c3750-i9-mz.122-20.SE3/c3750-i9-mz.122-20.SE3.bin"
cisco WS-C3750G-12S (PowerPC405) processor (revision H0) with 118784K/12280K bytes of memory.
Processor board ID CAT0841Y022
Last reset from power-on
7 Virtual Ethernet/IEEE 802.3 interface(s)
12 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:12:43:7E:74:80
Motherboard assembly number : 73-8307-08
Power supply part number : 341-0048-01
Motherboard serial number : CAT084103ZB
Power supply serial number : DTH08361BED
Model revision number : H0
Motherboard revision number : A0
Model number : WS-C3750G-12S-S
System serial number : CAT0841Y022
Top Assembly Part Number : 800-21966-01
Top Assembly Revision Number : K0
Version ID : N/A
Hardware Board Revision Number : 0x07
Switch Ports Model SW Version SW Image
* 1 12 WS-C3750G-12S 12.2(20)SE3 C3750-I9-M
Configuration register is 0xF
Please helpe me it's very URGENT.
Thansk in ADV,
Vaib...
Solved! Go to Solution.
08-27-2010 09:04 AM
Hi Vaib,
No, it doesnt.
•To use PBR, you must have the IP services image installed on the stack master.
•To use PBR, you must first enable the routing template by using the sdm prefer routing global configuration command. PBR is not supported with the VLAN or default template.
Lei Tian
08-28-2010 03:41 AM
Hi Vaib,
Legally you need to purchase SMI to EMI license for upgrade, but the switch itself cannot prevent you just upgrade the code without buying the license. For my customer I will recommend them buy the license or contact the sales;for my lab I will just upgrade the code. I hope you understand I am not suppose to tell you do anything against the policy at here, so my answer to your question is you need to buy license for upgrade.
Lei Tian
08-27-2010 09:04 AM
Hi Vaib,
No, it doesnt.
Lei Tian
08-27-2010 12:14 PM
Dear Letian,
Thank you very much for your great support.
According to you we dont need to change WS-C3750G-12S-S switch. only chage IOS , IP Services in place of current IOS. and ip routing enable , no switchport commnad are also configure ??? in each port of cisco WS-C3750G-12S-S switch for PBR ??
But i didnt find any ip services IOS of this WS-C3750G-12S-S switch , which is support PBR.
please guide me.
Thanks in ADV,
08-27-2010 01:11 PM
Hi Vaib,
There is a license need to be purchased for upgrading to EMI; I cannot tell you whether it is suffician by just upgrade the code. Please check the Q&A
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_qas09186a00801b0971.html
Once you have ip service IOS in place, you have to make sure put 'sdm prefer routing' in configure and reboot the switch. There are other restrictions of using PBR on 3750, they all listed in the configuration guide.
Lei Tian
08-27-2010 11:20 PM
Dear Letian,
Thanks, i more confuse....
Should i need to upgrade IP Services IOS in this Switch WS-C3750G-12S-S
I have c3750-ipservicesk9-mz.122-50.SE.bin Image .
Can i upgrade this IOS in WS-C3750G-12S-S switch ??
it is support to upgrade this IOS ?? i am not sure abou that....
Please guide me!!!
Thanks in ADV,
08-28-2010 03:41 AM
Hi Vaib,
Lei Tian
08-28-2010 10:35 PM
Dear Letian,
Thanks so much when i upgrade c3750-ipservicesk9-mz.122-50.SE.bin in WS-C3750G-12S-S, now i am able to apply on each interface ip policy route-map abc.
Thanks once again
