Webcast-Catalyst9k
urgent igmp
Hello!
i dont have IGNP in my Network.and i want to disable it.i have 720 with this IOS:s72033-ipservicesk9-mz.122-18.SXE6a.bin.I Read this in some link provided by alan:
no ip igmp snooping explicit-tracking
no ipv6 mld snooping explicit-tracking
but in my 720 i dont have this:
DS2(config-if)#no ip igmp snooping ?
fast-leave Enable IGMP fast leave processing
last-member-query-interval Configure IGMP leave query timeout
mrouter Configure an L2 port as a multicast router port
querier Enable IGMP querier processing
ssm-safe-reporting Enable SSM Safe Reporting
static Configure an L2 port as a member of a group
10xs and plz help
Hall of Fame Super Bronze
Re: urgent igmp
Strange,
I have a 720 here and the command works per guidelines:
l2-entry-limit limit on the l2 entry that can be installed by IGMP snooping
limit Configure IGMP Snooping limits
However, I have SXF here, I wonder if SXE did not provide the ability to disable IGMP snooping.
Re: urgent igmp
hello edison
i dont have this:explicit-tracking
Re: urgent igmp
You need to type that command under the intended interface:
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_02.html#wp1013416
Can you post the output from typing show version from the switch ?
Re: urgent igmp
System returned to ROM by power cycle (SP by power on)
System image file is "bootdisk:s72033-ipservicesk9-mz.122-18.SXE6a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID SMC1101003A
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
55 Virtual Ethernet/IEEE 802.3 interfaces
194 Gigabit Ethernet/IEEE 802.3 interfaces
4 Ten Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
149
