USB to RJ45 serial cable
Does anyone know of a one piece USB to RJ45 serial cable that is compatible with Cisco devices. I know that I can get USB to DB9 and then attach a standard Cisco console cable but I am hoping to find something a bit neater.
If it can support the Cisco break sequence that would be ideal.
1 REPLY
Purple
Re: USB to RJ45 serial cable
Haven't seen one but it doesn't mean they don't make one . Most people use what you indicated usb to db9 with the console cable and it works pretty well. The break sequence is determined by the emulation program you are using as far as I know.
1649
