Webcast-Catalyst9k
username on routers
Hi all , when I configure a username and password on the router, what is this classed as? aaa ?
Re: username on routers
It's just a local username database. You then enable AAA to use the local database.
It's also a good idea if you end up using tacacs or radius for aaa to configure AAA to use local as a last resort, that's where the username/password command can come in as a last resort if your tacacs/radius servers are unavailable. Just remember, your security is only as good as your passwords.
126
