07-01-2009 11:16 AM - edited 03-06-2019 06:32 AM
Does anyone know how or if you can setup 3560 using DHCP to assign VLAN to Avaya 4600 series IP Phones? I have no open RJ45 wall jacks and will need to hookup the switch has a standalone plugged into the RJ45 wall plate. From there I will hook up 30+ phones directly into the switch.
07-01-2009 12:38 PM
I'm not sure I understand your question, but if you want to use the 3560 itself as a DHCP server you are out of luck. It does not have that capability.
07-02-2009 05:10 AM
How do you configure DHCP on 3560 switch
07-02-2009 05:22 AM
It depends upon u r planning to have any vlanson it or in ur network.
suppose u r having a vlan in it the config would like below.
interface vlan 100
ip address 100.100.100.1 255.255.255.0
no shut
exit
ip dhcp pool avaya
network 100.100.100.0 255.255.255.0
default-router 100.100.100.1
and u need some other configs if u r planning for ip phones like option 150 etc.
Mahmood
07-02-2009 05:32 AM
Thanks, yes I will be having vlan and plugging Avaya 4600 ip phones into the switch
07-02-2009 05:46 AM
in that case make sure that u specify option 150 and the address of the tftp server.
Mahmood
