Bronze
Using Clustered ASAs in Transparent mode to support VRF based Network ?
Hi Guys,
I'm investigating the ways that I can use 2 x ASA (5525x) to accommodate Multi-tenancy situation with overlapping addresses. Unfortunately in this particular scenario we have to stick with 5525x firewalls.
The ASAs are going to be placed in north-south traffic path between 2 routers and these routers need to be configured with multiple VRFs to segregate the traffic for each tenant with overlapping IP subnets ( We are not looking at NAT as a workaround for the time being).
As we know, this ASA model won't support VRFs so we can't use the ASA as a intermediary routing hop and therefore this is not an option.. and using security contexts per VRF seems not scale-able enough (correct me if I'm wrong). So my thinking is that, if we put the ASAs in to the transparent mode and just use the ASAs as a layer 2 interconnect (configured with different VLANs connecting VRFs served by top and bottom routers)  I should be able to go up to maximum of 50 VRFs (since 5525x only supports 200 VLANs).
I'm also planning to use the 2 ASAs in a cluster mode to aggregate the bandwidth of both ASAs for better throughput.
So I need to clarify following with you guys..
1) Can I actually do this or am I missing something.
2) Are there any limitations that I might run in to with this setup
3) Is there anyone out there who's doing the same thing or can you think of a better way to tackle this scenario (with same hardware and requirements)
4) Instead of using clustering, can I use simple Active/Stanby pare and still configure transparent mode and use it that way ?
Appreciate your input.
Shamal
1 REPLY
Bronze
Is any expert out there who
Is any expert out there who can answer my query ?. Much appreciated.
66
