Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
using hostnames for NTP server
I added a couple of NTP servers to my router using hostnames. When I checked the config I see that the router resolved the names and added them to the config as IP address instead of hostnames. I realize that the IPs of public timeservers probably don't change much but isn't it more convenient to use hostnames just in case? Is there a way I can get my router to not convert hostnames to IPs in the config?
Diego
Re: using hostnames for NTP server
Unfortunately not. It looks up the names as you type them into the config, and fixes the addresses. There is nothing dynamic about it. It doesn't even re-resolve when you boot.
It's the same with other things like SNMP and logging server addresses.
Kevin Dorrell
Luxembourg
Kinda weird. I guess we'll just have to live with it.
Diego
231
