Using multiple ethernet ports to aggregate throughput on microsoft servers
We have not done this before. Should I just create a port channel for each of the servers NIC cards and assign the VLAN to the port channel?
1 REPLY
Hall of Fame Super Bronze
Re: Using multiple ethernet ports to aggregate throughput on mic
At the switch side, you need to configure etherchanneling which is described on this link:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/swethchl.htm
I recommend selecting the mode 'on' for the channel-group.
At the server side, I recommend reading the documentation on how to configure a channel for aggregate throughput.
HTH,
361
