11-24-2006 04:00 PM - edited 03-05-2019 01:01 PM
I'm trying to setup route redundancy using a default route and the tracking feature. Once upon a time I had this working on a 2800 router and am now trying to get it to work on a multilayer 3560 switch. I have the tracking commands available in my IOS on the 3560, but am not able to append the track keywork on my ip route command. Does anyone know if it will work on a 3560 with a particular IOS, or do I need a full blow router? My 3560 IOS version is Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(25)SEE1, RELEASE SOFTWARE (fc1)
thank you,
Bill
Solved! Go to Solution.
11-24-2006 08:26 PM
Hi Bill,
I am in doubt that 3560 supports this feature.
Though the IOS has commands for that.
What SDM template you are running on the switch.You can try changing the SDM template to routing but I am in doubt that still it will help us.
Show sdm prefer
config t
SDM prefer routing
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/swsdm.htm
This feature is not supported on layer3 switches yet.
HTH,
-amit singh
11-24-2006 08:26 PM
Hi Bill,
Show sdm prefer
config t
SDM prefer routing
HTH,
-amit singh
11-26-2006 07:37 AM
thank you.
