VACL-3750
Hello Everybody
I´m facing to one issue with VACL
i have a network lan with 10.40.X.X/16
in this network i have a Production vlan 10 with 10.40.10.X/24
and i have created one vlan103 for Guest´ user as 10.40.103.X/24
My goals is to restric the vlan 103 to reach or access the vlan 10, better to restric Guest user access to the production vlan
So i  try to put this script with VACL method, but doesn´t work
Extended IP access list Restriction-Guest
    10 permit ip 10.40.103.0 0.0.0.255 any
vlan access-map Guest 10
action drop
match ip address Restriction-Guest
vlan filter Guest vlan-list 10
After that i still able to ping or access to the vlan 10 form vlan 103
Ps: I have a CORESW 3750 S
Thank you in advance
VACL-3750
Hi Junior,
Instead of you denied the Production network access from Guest network you have permitted.
Do like below to achieve your goal...
ip access-list ext Restrict_Guest.
deny ip any 10.40.10.0 0.0.0.255
permit ip any any
int vlan 103
ip access-group Restrict_Guest
Hope the above clear and understand you.
Please rate all the helpfull posts.
Naidu.
VACL-3750
Hello Naidu
and thank you for you response,
i have finish to test this script with this correction but it does´nt work.
i still able to connect to the vlan production(10) from vlan guest(103)
VACL-3750
Hi Junior,
It is strange.
Can you provide your 3750 switch config.
Naidu.
VACL-3750
COBswCR#sh version
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01080000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
COBswCR uptime is 17 minutes
System restarted at 12:58:33 UTC Wed Feb 8 2012
System image file is "flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE5.bin"
cisco WS-C3750-24P (PowerPC405) processor (revision T0) with 118784K/12280K bytes of memory.
Processor board ID FDO1428X3SY
Last reset from power-on
9 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : DC:7B:94:CD:B3:00
Motherboard assembly number     : 73-9672-15
Power supply part number        : 341-0029-05
Motherboard serial number       : FDO14290D7M
Power supply serial number      : LIT14200UMD
Model revision number           : T0
Motherboard revision number     : A0
Model number                    : WS-C3750-24PS-S
System serial number            : FDO1428X3SY
Top Assembly Part Number        : 800-25860-09
Top Assembly Revision Number    : A0
Version ID                      : V10
CLEI Code Number                : COMAJ10BRA
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   26     WS-C3750-24P       12.2(35)SE5             C3750-IPBASE-M
Configuration register is 0xF
COBswCR#sh run
COBswCR#sh running-config
Building configuration...
Current configuration : 3805 bytes
! Last configuration change at 13:03:44 UTC Wed Feb 8 2012
! NVRAM config last updated at 13:03:46 UTC Wed Feb 8 2012
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname COBswCR
username admin privilege 15 password 7 046B5A0A5F3545565B495446
no aaa new-model
switch 1 provision ws-c3750-24p
system mtu routing 1500
ip subnet-zero
ip routing
no ip domain-lookup
ip domain-name cobeje.co.ao
no file verify auto
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
spanning-tree uplinkfast
spanning-tree backbonefast
vlan internal allocation policy ascending
interface FastEthernet1/0/1
description PORT_RESERVED_Vmware-SRVPROD
switchport trunk native vlan 99
switchport mode trunk
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
switchport access vlan 31
switchport mode access
interface FastEthernet1/0/21
description LINK of TEST
switchport access vlan 10
interface FastEthernet1/0/22
interface FastEthernet1/0/23
description LINK-TO-Router(SPOKE)
switchport access vlan 32
interface FastEthernet1/0/24
description LINK_TO_ASAFW
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
description Servers Production
ip address 10.40.10.254 255.255.255.0
interface Vlan12
description vlan Reserved for DOMAIN CONTROLLER
ip address 10.40.12.254 255.255.255.0
interface Vlan14
description (FFTMG,MACAFEE,WSUS,..)
ip address 10.40.14.6 255.255.255.248
interface Vlan31
description LINK-to-ASA (Layer1)
no ip address
shutdown
interface Vlan32
description LINK-TO-RT(spoke)
ip address 172.40.32.1 255.255.255.252
interface Vlan98
description Management dos Servidores da Rede
ip address 10.40.98.254 255.255.255.0
interface Vlan99
description ONLY FOR DEVICE MANAGEMENT
ip address 10.40.99.254 255.255.255.0
interface Vlan103
ip address 10.40.103.14 255.255.255.240
router eigrp 40
variance 2
redistribute connected
passive-interface default
no passive-interface Vlan31
no passive-interface Vlan32
network 172.40.32.1 0.0.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.40.14.1
ip http server
control-plane
line con 0
privilege level 15
login local
line vty 0 4
privilege level 15
login local
line vty 5 15
login
ntp clock-period 36028756
ntp server 192.168.10.9
end
476
