Verify Fiber 10G SFP mod on WS-C2960S-24TD-L
Hi...
For a project I purchased two qty of WS-C2960S-24TD-L switches and two qty of SFP-10G-SR=  modules that will sent to customer site.
I wanted to verify the 10G uplink interface on both switches, so I simply plugin a LC-to-LC fiber cable to both switches on interface TenGigabitEthernet1/0/1.  But the LED link light won't come on.    Does anyone know why?  Is there a license needed?  I even swamp one end of the LC fiber to B-A to simulate crossover cable.    Example: AB - BA
As you can see from show inventory, it listed both parts.
switch#show inventory
NAME: "1", DESCR: "WS-C2960S-24TD-L"
PID: WS-C2960S-24TD-L  , VID: V02  , SN: xxxx
NAME: "TenGigabitEthernet1/0/1", DESCR: "SFP-10GBase-SR"
, V , SN: xxxx
Version 12.2(55)SE3  SW image: C2960S-UNIVERSALK9-M
Switch#show int te1/0/1
TenGigabitEthernet1/0/1 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is 24b6.5739.a61b (bia 24b6.5739.a61b)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Software's got NOTHING to with it.  The 2960S that you have supports 10Gbps straight up.  There's no special software, there's no special license, there's no special "human sacrifices".
It's either you have a faulty cable, faulty SFP+, or worst yet, a faulty unit.
I mean you can swap out the first two items three times.
Change the multi-mode fibre optic three times, swap the SFP+ three times ...
Make sure that when you swap the end-points around too.
Verify Fiber 10G SFTP mod on WS-C2960S-24TD-L
Looks like a Layer 1 issue.  No you don't need a license.
How come in your "sh inventory" the SFP+ isn't showing up?
Can you post the "sh log"?
Have you tried "flipping" the terminating end of the LC cable?  Should be like this:
send < --- > receive
receive < -- > send
that's all it show from "sh invent"
Switch#show inven
PID: WS-C2960S-24TD-L  , VID: V02  , SN: xxxxx
, V , SN: xxxxx
Yes I did flip the LC cable end already...
Sh log
*Mar  1 00:00:12.247: Read env variable - LICENSE_BOOT_LEVEL =
*Mar  1 00:00:12.907: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960s_lanbase Next reboot level = lanbase and License = lanbase
*Mar  1 00:01:32.295: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Mar  1 00:01:33.517: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:01:34.272: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar  1 00:02:09.562: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:02:09.761: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Mar  1 00:02:09.761: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar  1 00:02:09.761: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Mar  1 00:02:10.175: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Mar  1 00:02:10.201: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 16:56 by prod_rel_team
*Mar  1 00:02:10.657: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar  1 00:02:11.182: %LINK-5-CHANGED: Interface FastEthernet0, changed state to administratively down
*Mar  1 00:02:11.517: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Mar  1 00:02:12.183: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar  1 00:02:14.207: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
Switch#
VIP Super Bronze
Your optic is multimode.  Is your patch cord also multimode?
Hi...What does this tell me?
Switch#sh idprom int ten1/0/1
        SEEPROM contents (hex) size 256:
          0x00: 03 04 07 10 00 00 00 40 40 0C 00 03 67 00 00 00
          0x10: 1E 1E 00 00 43 49 53 43 4F 2D 46 49 4E 49 53 41
          0x20: 52 20 20 20 20 24 00 00 46 54 4C 58 38 35 37 31
          0x30: 44 33 42 43 4C 2D 43 53 56 30 32 20 03 52 00 E9
          0x40: 00 1A 00 00 46 4E 53 31 35 31 32 31 43 56 4E 20
          0x50: 20 20 20 20 31 31 31 30 32 35 20 20 68 F0 01 45
          0x60: 00 00 01 16 46 A2 1A 11 B7 6E 1C 45 EA BF EF 4B
          0x70: D7 58 2D 00 00 00 00 00 00 00 00 00 5F 0C 92 CC
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF 03 40 00 00 00 00 00 00
SFP+ Transceiver Module Serial EEPROM Contents:
Common block:
Identifier        : SFP
Connector         : LC connector [0x07]
Transceiver
  Type             : SFP-10GBase-SR
  Speed            : [0x00]
  Media            : Multi-mode, 50u (M5), 62.5u (M6) [0x0C]
  Technology       : Shortwave laser w/o OFC (SN) [0x40]
  Link Length      : Short Distance (S) [0x40]
Encoding          : serial encoding algorithm 10GE, 64B/66B serial encoding alg                                           orithm 8GFC, 8B/10B [0x03]
BR, Nominal       : 103x100 MHz [0x67]
Rate Identifier   : [0x00]
Length(9u)        :
Length(50u)       : [0x1E]
Length(62.5u)     : [0x1E]
Length(OM3)       : [0x00]
Vendor Name       : CISCO-FINISAR
Vendor OUI        : 0x24 0x0 0x0
Vendor PN         : FTLX8571D3BCL-CS
Vendor rev        : V02
CC_BASE           : 0xE9
Extended ID Fields
Options           :
      Class   : Limiting Class [0x00]
      More Options   : 10GE - TX_DISABLE, TX_FAULT and LOS [0x1A]
BR, max           : Unspecified
BR, min           : Unspecified
Vendor SN         : F N S 1 5 1 2 1 C V N
Date code         : 111025
DOM Type          : DOM Internally Caliberated [0x68]
CC_EXT            : 0x45
Vendor Specific ID Fields:
  0x00: 00 00 01 16 46 A2 1A 11 B7 6E 1C 45 EA BF EF 4B
  0x10: D7 58 2D 00 00 00 00 00 00 00 00 00 5F 0C 92 CC
Device : SFP_PLUS PMA PMD
0000: 2040        :  0010 0000 0100 0000
0001: 0082        :  0000 0000 1000 0010
0002: 0020        :  0000 0000 0010 0000
0003: 6036        :  0110 0000 0011 0110
0004: 0001        :  0000 0000 0000 0001
0005: 009B        :  0000 0000 1001 1011
0006: 0000        :  0000 0000 0000 0000
0007: 0008        :  0000 0000 0000 1000
0008: BF01        :  1011 1111 0000 0001
0009: 0000        :  0000 0000 0000 0000
Device : SFP PLUS PCS
0007: 0000        :  0000 0000 0000 0000
0008: 8C01        :  1000 1100 0000 0001
Device : SFP_PLUS XGXS
0002: 0143        :  0000 0001 0100 0011
0003: BFF0        :  1011 1111 1111 0000
0005: 0093        :  0000 0000 1001 0011
0008: 8C00        :  1000 1100 0000 0000
00-00-00, 00-00, 01-02
Switch#
Re: Verify Fiber 10G SFP mod on WS-C2960S-24TD-L
It's telling me what the s/n of your SFP+ is and who is the manufacturer.  If this was a fake then this output would not be valid.
RMA the module.  I believe it could be faulty.
Thanks for the output.  Can I also ask if you can provide the output to the command "sh idprom interface Ten 1/0/1"?
Switch#show logging
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 26 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 26 messages logged, xml disabled,
*Mar  1 01:19:24.378: %SYS-5-CONFIG_I: Configured from console by console                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 29 message lines logged
Log Buffer (4096 bytes):
*Mar  1 00:00:12.252: Read env variable - LICENSE_BOOT_LEVEL =
*Mar  1 00:00:12.913: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960s_lanbase Next reboot level = lanbase and License = lanbase
*Mar  1 00:01:32.358: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Mar  1 00:01:33.580: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:01:34.335: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar  1 00:02:09.682: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:02:09.876: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Mar  1 00:02:09.876: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar  1 00:02:09.876: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Mar  1 00:02:10.290: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Mar  1 00:02:10.317: %SYS-5-RESTART: System restarted --
*Mar  1 00:02:10.773: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar  1 00:02:11.318: %LINK-5-CHANGED: Interface FastEthernet0, changed state to administratively down
*Mar  1 00:02:11.653: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Mar  1 00:02:12.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar  1 00:02:14.322: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
*Mar  1 01:06:26.696: %LINK-5-CHANGED: Interface TenGigabitEthernet1/0/1, changed state to administratively down
*Mar  1 01:06:40.401: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/1, changed state to down
*Mar  1 01:07:02.573: %LINK-5-CHANGED: Interface TenGigabitEthernet1/0/1, changed state to administratively down
*Mar  1 01:07:09.341: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/1, changed state to down
*Mar  1 01:07:42.083: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 01:16:44.181: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 01:18:17.174: %LINK-3-UPDOWN: Interface Vlan1, changed state to up
*Mar  1 01:18:30.832: %LINK-5-CHANGED: Interface TenGigabitEthernet1/0/1, changed state to administratively down
*Mar  1 01:18:37.480: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/1, changed state to down
Switch#
A few things...
Are you using OM3 fiber?
Can you post your interface config
Can you post sh int trans detail from both switches while the links are plugged in
Udld enabled?
Do you have van created that is assigned to port if access?
I havn't done any configuration.
Default config...
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface TenGigabitEthernet1/0/2
interface Vlan1
no ip address
shutdown
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
login
line vty 5 15
login
end
2172
