Very General PIX config
I'm having problems w/ a Pix that isn't able to be ping'ed. If I ping from the PIX(515) to the device it isn't a problem but when I try to originate the ping from my laptop I'm having problems. I'm trying to setup a very simple firewall that allows all traffic to come through the device in both directions, then I want to increase security once the basic functionality is there. So what is the best way to go ahead and do this? I don't have my book yet and the online documentation isn't great. Thanks.
1 REPLY
Re: Very General PIX config
PIX Initial Configuration:-
pixfirewall(config)# hostname PIX1
PIX1(config)# enable password enable-password-here
PIX1(config)# passwd telnet-password-here
PIX1(config )# write mem
Interface Security:-
PIX1(config )# nameif ethernet0 outside sec0
PIX1(config )# nameif ethernet1 inside sec100
Interface Speed:-
PIX1(config )# interface ethernet0 100full
PIX1(config )# interface ethernet1 100full
IP Address Config:-
PIX1(config)#ip address inside
PIX1(config)#ip address outside
PIX1(confi)#ssh inside
PIX1(config)#global (outside) 1 netmask
PIX1(config)#nat (inside) 1 0 0
PIX1(config)#access-list acl-per permit ip any any
PIX1(config)#access-group acl-per in interface outside
PIX1(config)#access-group acl-per in interface inside
PIX1(config)#route inside 1
PIX1(config)#route outside 0 0 1
PIX1#wr
Connwect your laptop to the inside interface. Assign IP address to your laptop of inside subnet.
It should work.
Hope That Helps.
Suresh Jain
123
