10-19-2009 02:03 PM - edited 03-06-2019 08:11 AM
Hey all,
I'm a CCNA without any real world experience. I'm trying to find a WIC for a 2801 that has at least one gigabit interface (fibre). I've been digging around for half an hour online, and most of what I find is HWICs, which it looks like the 2801 doesn't support. What do I need?
Thanks in advance. ;)
10-19-2009 02:11 PM
10-19-2009 02:41 PM
That one specifically says "except the 2801". :(
10-19-2009 03:11 PM
I did read your post too fast.
There is no HWIC for the fiber for 2801.
You need to upgrade the router for that feature.
10-19-2009 08:54 PM
Hi Anthony,
The links which Lucien has sent states that this GE HWIC is supported on a 2801 router with IOS 12.4(15)T9, IP Base, Table 2.
As far as HWIC slot on 2801 is concerned you get -
2 slots which support HWIC, WIC, VIC, or VWIC
1 slot which supports WIC, VIC, or VWIC 1 slot which supports VIC or VWIC
So to me it looks like HWIC-1GE-SFP is supporte on 2801 router.
-> Sushil
10-21-2009 05:35 AM
Correct, the HWIC-1GE-SFP is supported with 12.4(15)T9 or newer. But as Guiseppe writes, you shall not expect to have a full 1GE throughput.
10-20-2009 01:37 AM
Hello Anthony,
be aware that a GE port on a C2801 would be just nominal : router performance are far lower then a GE port.
It could just solve an interconnection issue.
Have you got a free FE port on the device?
Hope to help
Giuseppe
