Video Conferencing - Cisco881w Polycom HDX 8000
I have just setup a Polycom HDX 8000 on our Cisco 881w for Video conferencing. The 881s WAN interface is connected to the ISP router and configured as a L3 interface. The Polycom is attached to a switchport (Fa1) and sits on a private VLAN. - 192.168.254.1 /24
There is a static NAT statement for the VC unit
There are no IP inspect statements or ACLs enabled on the VLAN or int Fa4
I can reach the router and the VC unit from the internet
When i place a call from the VC it connects but i dont get any Voice or video. I have tested with multiple sites and i get the same result. Doing some debugging i see that there are no UDP packets sourcing from the remote VCs IP. I do see packets being sourced from my Public and Private IPs.
Also when the Video conferencing unit is attached directly to the ISP router and configured with a Public IP it is able to make calls as expected.
Any thoughts ?
vlan20
ip address 192.168.254.1 255.255.255.0
ip nat inside
interface Vlan20
description VC_VLAN
ip nat inside
ip virtual-reassembly in
end
description EXTERNAL Time Warner 82.100.105.162
ip address 82.100.105.162 162 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip tcp adjust-mss 1300
duplex auto
speed auto
no cdp enable
ip nat inside source static 192.168.254.3 82.100.105.165
212
