12-14-2011 12:44 AM - edited 03-07-2019 03:53 AM
Hi, I have a lots of cisco catalyst switches, and I need to find out wich switch has port with port-security feature disabled.
I have a comand show port-security, but it shows me just enabled port-security feature on ports, but I need opposite info, may be someone know how to view port table without port security
thanks
12-14-2011 12:50 AM
sh interface status err-disabled
12-14-2011 01:12 AM
thanks but, I think you dont understand my question, your comand just shows err-disabled port, but with ports everything OK, they are int working state, no violation happends for now. let me explain on example, I have two ports in my config
interface FastEthernet0/2
switchport mode access
switchport block multicast
switchport block unicast
switchport port-security
switchport port-security violation restrict
switchport port-security mac-address sticky
storm-control broadcast level 5.00 4.00
storm-control multicast level 5.00 4.00
storm-control action trap
interface FastEthernet0/3
switchport port-security maximum 2
on interface 0/2 I have a command
it means my port is secure
on interface 0/3 I dont have this command
it means it's unsecure
so I need to some show...bla-bla-bla writen in one line to see ONLY unsecure interfaces
03-15-2012 06:01 AM
Is this good enough ?
sh ru | i (interface|port-security)
or
sh ru | i (interface|violation)
This will still give you all ports but it will also tell you wich are configured and wich is not configured.
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
as you can see here Gig1/0/8 is configured the others are not since they have no row of switchport port-security beneath them.
This sh ru will pick out any line with "interface" and any line with "port-security" (or "violation)
Good luck
03-15-2012 06:21 AM
thanks, but this comands just show interface number and lines with %port-security%, in your example it doesn't mean that
interface configured for port security, because only intrface with \switchport port-security\ and nothing after that is secured, for example:
(non secured)
sh run int g1/0/8
(secured)
sh run int g1/0/8
How can just interface with this?
03-15-2012 06:27 AM
If you use the word port-security instead of violation then it will show you just that.
It will still give you all the rest but it will give you the line with port-security only.
so you will be able to tell if it is connected or not.
03-15-2012 06:30 AM
@hobbe:
Thank you very much. You point me to the right direction.
@Krasnoperov
Can you try this command?
sh ru | i (interface|port-security$)
12-14-2011 12:54 AM
sh run | exc port-security
Regards.
Alain
12-14-2011 01:15 AM
nope it's just shows ALL (not just inteface section) line in my config WITHOUT port-security lines, and I see all interfaces with&without portsecurity
12-14-2011 02:14 AM
So you want to see wich port are not configured with port-security command...I don't think it's possible... it is faster to do a show run and use find function. But maybe i'm wrong... i've thinked same solution who Cadet had suggested but if not work i've no idea...
12-14-2011 03:03 AM
I've got no switch here to verify but you could try sh run interface | exc port-security
Regards.
Alain.
12-14-2011 05:54 AM
I just tested that cadet, if you do that, it will show all ther interfaces but just excluding the port-security configuration statements. I was not able to get a single command to do this, but you can modify the following one.
show port-security interface gi0/1 | i Port Security|Disabled
This will show you if the port has port security enabled or disabled.
You can just modify each statement if you want. Personally I would
just do a show run, but each his own.
Hope that helped.
12-18-2011 11:48 PM
thanks but it's only for 1 port, and I need to view all ports, so I need to do this command for each
12-18-2011 11:49 PM
sh run interface
% Incomplete command.
so I need to define just one interface in this command,
12-19-2011 04:34 AM
You could setup a macro to do this for you actually....
